X-post: Why is my Demo 7 still heavy?- Mtbr.com
Results 1 to 17 of 17
    New question here. X-post: Why is my Demo 7 still heavy?
    X-post from specialized forum. So I just weighted my bike yesterday and I was upset to find out that my bike was still 41.87 pounds! I know it is pretty light, but I was hoping to get it to 39, low 40.
    I started with a stock 2007 Demo 7 I and have upgraded, heres the specs.
    Fork: Boxxer Team
    Stem: Sunline direct mount
    Bars: Sunline V1
    Brakes: Juicy 7
    Seat: SDG Ti Fly
    Grips: ODI
    Headset: Cane Creek Double XC flush
    Tires: Kend Nevegal 2.5f 2.35f
    Ti coil
    Pedals: 5050XX
    Chainring: E-13
    Cassette: Sram PG-970 road 12-26
    Chain: Pg991
    I have 823 being laced up to the stock hubs now. Everything else is stock.
    What is wrong with my build? I figured it would be down to low 40 at least by now.
    Go BIG or Go HOME
    Glad to Be Alive
    get lighter pedals and running the 823's tubeless will get you down to that number you want
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    You can drop a bit by swapping to some lighter pedals (magnesium) but that won't get you to 40 lbs... It's going to be pricey getting that weight any lower and then you have to think about durability with all the lighter parts. I'd just ride the hell out of it as is, after all it's not a XC ride
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Glad to Be Alive
    Quote Originally Posted by kenbentit
    2 pounds is easy....swapping to lighter rims, getting rid of innertubes by running tubeless and swapping pedals will easily drop it 2 pounds
    dont worry about it to much ay its ment for dh and freeride so rip it up man as kenbentit said it isnt xc
    Reputation: rollertoaster's Avatar
    lighter pedals. you could convert your boxxer to a WC air spring. You could also get some Hope 2 piece rotors, they have an aluminum center hub and they are significantly lighter than steel rotors.
    Team _________
    Reputation: combatkimura's Avatar
    what seatpost are you running? That could help with about .25 .5 lbs. Lighter pedals for sure. I run Drive Technologies Pro, they're super light, very durable and relatively inexpensive ($65). They would save you close to a pound.
    i eat rocks
    Reputation: gil_caz's Avatar
    823 along with tubeless set up will save you some wieght like smt said...
    that was the main upgrade that got my V10 under 40 lbs.
    but the cheap things to upgrade will be pedals, and seatpost.
    the one that will make your bike feel way different, is the rims with tubeless.
    Why is my build 42#, when a 2008 Demo 8 II came stock at 39.5 pounds? doen't make sense except for the mag link.
    Go BIG or Go HOME
    StraightOuttaCompton
    Reputation: Djponee's Avatar
    its because specialized is full of ****.
    HARDTAIL PRIDE- 09 Kona Five-0
    why do you care? ride your bike, weight reduction of 2lbs is WAY over rated unless it is in the wheels.
    just get a faster rolling tire. It helps. Seriously.
    Reputation: zark's Avatar
    Dec 2004
    What chainguide are you running? Saved 0.6lb by going to an LG1 from an SRS
    Intense-Hutchinson-Nema
    Fearing the Reaper
    Reputation: GLIDE's Avatar
    What cranks/BB setup are you running?
    Holzfeller/howitzer for cranks and gamut p40.
    Go BIG or Go HOME
    Premium Member
    Reputation: Ojai Bicyclist's Avatar
    Hubs! Specialized hubs (especially rear) are beeeefy. Get Hope Pro IIs.
    Calm Like a Bomb
    Reputation: pipes10's Avatar
    Quote Originally Posted by Ojai Bicyclist
    yeah they are heavy....lacing the 823s to hope pro 2s and running tubeless will save u the most weight
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    https://www.instagram.com/jayparrington/
