X-0 long cage vs X-0 medium Cage rear Der.- Mtbr.com
    Apr 2005
    Sup peeps,
    just had a quick question, i currently ride a 05 Yeti ASX hence my S/name....and was wondering with TRUVATIV HOLZFELLER 32/22 crank set with only 2 rings. If i switch to a X-0 rear derailer (long cage) with X-9 tiggers with there be any major difference between staying with long cage vs medium cage....any info will be helpful....
    Peace.
    M
    Reputation: Red Bull's Avatar
    Go medium. It's shorter therefore less prone to getting hit on rocks, it also is shorter meaning less area to bend/break...
    Quote Originally Posted by Mouse
    what were is gnarcal
    Mike? hahha its me john.. it should work fine.. just might be better to have shorter cage.. the long cage makes up for the extra chain length required to run a big ring.. but its fine.. since with a long cage on a 3-ring setup.. you can choose to use your front 2 rings only and have it still work.
    there were a few threads on it... heres one: http://forums.mtbr.com/showthread.ph...ong+short+cage
    Trail rider and racer
    Reputation: Trevor!'s Avatar
    Medium will be fine to use, either on a double or triple (As long as on a triple you don't cross chain).
    Trev!
  1. medium or long cage derailleur?
    By otis24 in forum Turner
    Last Post: 04-13-2005, 07:35 AM
  2. rear derailluer: long cage vs. super long cage
    By roncox02 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-06-2005, 07:39 AM
  3. help: medium or long cage x9 rear D
    By danK in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-26-2004, 04:52 PM
  4. X.O. rear der cage stop screw
    By J_B in forum SRAM
    Last Post: 04-07-2004, 01:09 PM
  5. Replies: 1
    Last Post: 03-31-2004, 08:26 AM
