will Fox Van RC fit my bike?- Mtbr.com
Results 1 to 3 of 3
    RTM
    RTM is offline
    #1 Latex Salesman
    Reputation: RTM's Avatar
    will a Fox Vanilla RC fit an '04 demo 9? eye to eye and spring are right (9.5 x 3), but I'm not sure if there are other factors to consider.
    Reputation: GnaR9's Avatar
    It should fit fine, but needs specific hardware you should be able to find at specialized, unless your last shock was a Fox. At least I think.......
    Bike Ninja |||
    Reputation: chooofoojoo's Avatar
    Feb 2007
    what is you're current shock? if it's a fox then you might be outta luck.. they had a special mounting hole on one end (very small). you might be able to get some custom mounting hardware made to reduce it to that size however.
    Proud to represent Mojo Wheels.
