Who makes the longest direct mount stem?- Mtbr.com
Results 1 to 11 of 11
    Jun 2010
    Any ideas? Longest i can find is Burgtec's at 60mm
    Jan 2003
    Maverick but chances are that you wont want that.
    Jun 2010
    Maverick, never heard of them in the UK.
    I'd consider it definitely, why wouldn't i want one?
    Do they fit Boxxer direct mount pattern?
    Jan 2003
    Won't fit boxxer mount thats for sure.. for their DC xc forks..
    Jun 2010
    Hmmm, bugger.
    Ok, except Maverick then, any more contenders?
    Reputation: kipdrunner's Avatar
    Does the Boxxer DM Standard specify a maximum length? Maybe they don't want so much leverage on those 4 little bolts.
    Reputation: CA_Descender's Avatar
    Twnty6 F1 - adjustable 45,50,55
    Answer DH direct mount 45,50,55
    Deity Fantom 48,55
    Nov 2008
    Direct mounts are meant to be low and have a short reach. With that being said I think you arent going to find many direct mount stems longer than 60mm, that is pretty much the longest I have seen them.
    i think boxxer makes largest mount stem because on a flush Cane Creek Double Xc II headset and a Straitline 50 mm direct mount stem. The front end ends up so low with this configuration at 25mm rise Chromag Fubars OSX bars to find your balance point. If you like a low front end, you’ll love the head tube on the Podium. With the flush mount headset and your fork crowns dropped 20 mm..
    Feb 2005
    Truvative Holzfeller is available in 60mm
    -Skimming the successpool of corporate America-
