White spokes- Mtbr.com
Results 1 to 19 of 19
Thread: White spokes
    Roll on Spring Time!
    Reputation: juan pablo's Avatar
    White spokes
    Looking to build up a set of green subrosa rims and was considering white spokes. What are the options for to check on availablity? How durable are they, I mean, does the paint flake off? My wheels generaly last a while so wood prefer them to look reasonably good till they die.
    I know DT Swiss makes the competitions in white. They are almost triple the price though I think.
    Go BIG or Go HOME
    Meh.
    Reputation: XSL_WiLL's Avatar
    From BTI
    DT-Swiss Competition 14/15/14g (white) Spoke
    * Double butted 2.0/1.8/2.0mm with cold forging technology
    * Chrome nickel stainless steel with rolled threads. White surface treatment resists scratches
    * Includes 12mm 14g black alloy nipples
    * 191g @ 32h/265mm
    * Box of 72
    item # size in stock?
    DetailsDT-733254 254mm YES
    DetailsDT-733256 256mm YES
    DetailsDT-733258 258mm YES
    DetailsDT-733260 260mm NO
    DetailsDT-733262 262mm YES
    DetailsDT-733264 264mm YES
    DetailsDT-733266 266mm YES
    DetailsDT-733268 268mm YES
    DetailsDT-733270 270mm YES
    DetailsDT-733280 280mm YES
    DetailsDT-733282 282mm YES
    DetailsDT-733284 284mm YES
    DetailsDT-733286 286mm YES
    DetailsDT-733288 288mm YES
    DetailsDT-733290 290mm YES
    DetailsDT-733292 292mm YES
    DetailsDT-733294 294mm YES
    DetailsDT-733296 296mm YES
    DetailsDT-733298 298mm YES
    DetailsDT-733300 300mm YES
    Any bike shop can order them. Sorry... can't comment on durability. DT makes some good stuff though. And it says it resists scratches... If it's like their black spokes, the finish is pretty durable.
    Meh.
    Halo makes these powdercoated spokes... Though I'm wary of the PC being too thick to fit through the hub... and I had some SAS rims where the PC was not that durable.
    Halo Aura 14g (white) Spoke
    * Proof that bling white powdercoated spokes don't have to cost a fortune
    * Straight gauge stainless steel, durable coating resists scratches
    * Box of 100
    DetailsHL-4452 252mm YES
    DetailsHL-4454 254mm YES
    DetailsHL-4456 256mm YES
    DetailsHL-4458 258mm YES
    DetailsHL-4460 260mm YES
    DetailsHL-4462 262mm YES
    DetailsHL-4464 264mm YES
    DetailsHL-4466 266mm NO
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    You could also do the "custom" build from Atomlab. I did the same setup (green/white) but ended up swapping out the rear hub. Unfortunately they only have one length of spoke...
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Cheers guys, its the powder coat thing I was wondering bout. I will see what the shops says
    Reputation: stylie's Avatar
    why limit yourself to just white when you could choose from white, yellow, blue, pink, orange, black, red and the standard silver.
    http://www.prowheelbuilder.com/other...ucts&subcat=84
    Proud lame eBiker
    Reputation: Internal14's Avatar
    I build up a set of dh wheels this summer with the white DT spokes and they're holding up great. No scratches, as far as I can tell.
    They are bank though.....although, QBP has a 25% off right now, just saw that on a shop flyer. So if your shop is ordering them from QBP they aught to be able to give you a break a bit off the normal price, which is pretty exorbitant if you ask me.
    www.velocitybicycles.comWhere customers become friends, not simply a dollar sign.
    how do i know what size spokes i need?
    i know this sounds like a "noob" question
    Quote Originally Posted by giantsaam
    make dirt bike noises when you go through go brrraaapp brraapppp brraappp it helps keep your mind off how difficult it is
    Quote Originally Posted by justcheckin
    256mm, without a doubt.
    Meh.
    The length of the spokes will depend on the hub and the rim and the lacing pattern. If you don't know this, you probably should not build your own wheel.
    well my moms friend owns a bike shop, he said if i can get all the stuff i need hell lace it all up for me for a good price
    If he owns a bike shop can't you just get him to order the stuff for you?
    i can, but its gonna cost more
    Meh.
    Well if he's going to cut you a good deal on labor, why wouldn't he offer some sort of discount on the spokes? And if somebody were cutting me a great deal... I would throw some money back their way.
    or at least tell you the spoke length to get
    Pivotal figure
    Jan 2003
    The problem with those spokes is you'll be buying an entire box, that's where the high cost comes in. I just went with basic black for my rebuild...
    RIDE4FUN
    Reputation: mountain_yj's Avatar
    I'm kina interning at a shop right now. I was looking at some dt spokes in white, think I'll pull out the white rattle can. On that website up above it's 3.25 per spoke and 50 are in a box. 10 hot dogs 8 buns.
    Grassroots Cycles
    Check out our BLOG
    Reputation: tatankainlondon's Avatar
    DT Swiss also makes Aerolites in white - mega bucks, though. In the UK they are over 5GBP each spoke.
