Whats wrong with this picture?- Mtbr.com
Results 1 to 21 of 21
    dnt b a clwn thro it down
    Reputation: Swoop's Avatar
    Ok so I got my new bike but I think my shock may be too short. It looks like my chainstay is sloping down toward my bb. My current shock is a 2.25. Does anybody out there have an '03 Helius DH? Here are a couple pics to show you what I mean...
    From the center of the rear axle to the center of my bb it drops about an inch. Just to give you an idea of how slanted it is.
    Reputation: Coldfire's Avatar
    if it came stock, it must be good.
    Check out the homepage fot the right shock size, or call Nicolai.
    Coldfire
    LIVE FREE
    BE BRAVE
    RIDE HARD
    Authority is dead!
    Reputation: Lucky13's Avatar
    It's just that the shock in the the middle of tt, something we aren't seeing too often, that's why it doesn't look normal.
    For the love of Oi
    Rent a house at Attitash
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    Does the swingarm smack the front derailleur cage when compressing? It looks pretty close.
    If the BB drops an inch from the rear hub, that's not so low. Looks a little low compared to the newer Helius's though. Is that the stock shock?
    No it's not the stock shock. The guy that was making it up for me put the romic on because the orginal shock had too heavy of a spring. The swingarm doesn't smack the derailleur cage.
    Buckle Up
    Reputation: WheelieMan's Avatar
    It looks like you have the crowns on the fork down too far, if you move them up you will raise the bb a little bit. However the headangle might be too slack then, because you are using too short of a shock. Just buy the correct size shock.
    l337 |31k3r
    Reputation: Gramatica's Avatar
    Quote Originally Posted by WheelieMan
    Thats what it looks like to me.
    If you have the money, get a new shock on there. If you like the romic, raise the crows up a bit.
    People call me a dick, but I just think im clever.
    Honary member of the
    591 club & 773 club.
    Quote Originally Posted by Zedro
    what he meant was 'greaser' types, most likely performing choreographed musical outakes which somehow degrade dirt jumps...
    Does anybody know what the i2i or the shock stroke is supposed to be on this bike?
    In FTF We Trust
    Reputation: el-cid's Avatar
    Frame setup looks OK to me
    The frame/shock setup looks kosher to me. If you look at the pic. of the left chainstay, if the shock was any longer eye-to-eye, the chainstay would contact the bottom bracket... So what is the actual bb height as it sits?
    "I'll disintegrate over time if I expect my body to try to keep up with my mind" -BM
    Race, Rocks or Road...Just Ride
    Quote Originally Posted by el-cid
    When it is in the most travel setting the bb heght is 12.75".(I measure from the ground to the center of the bb) But here is a reason why I need a longer shock... Also I just noticed that my derailleur hanger will hit the frame!
    Buckle Up
    Quote Originally Posted by Swoop
    The derailleur hanger is what holds the rear derailleur on. So I think you mean the front derailleur will contact the chainstay? Yes you deffinately need a new shock.
    Ya that's what I meant the front derailleur...... but ya when I took the shock out and went through the travel it hit. Does anybody think that with a longer shock it won't hit?
    Buckle Up
    As long as you have the correct shock it wont hit. Unless you have your front derailleur installed incorrectly.
    It's definitely too short a shock. Looking at some of the newer Helius's, it looks pretty short. The easiest way to get the correct shock length is just to contact Nicolai.
    I emailed Nicolai so hopefully they can tell me what size shock is supposed to be in there.
    Let us know how it turns out...
    HAL
    HAL is offline
    Reputation: HAL's Avatar
    Just checked fox's app guide and
    The 03' helius DH uses a 8.75 x 2.75 shock considerably longer than what you've got on there. Check it out here, it's a great resource for most bikes.
    http://www.foxracingshox.com/website...rketSalesId=94
    Quote Originally Posted by HAL
    Hey man thanks a lot. That site is very useful. I even went to the Fox Shock site and didn't find anything. I will get back and post some pics of my bike finished.... Hopefully in a week or so.
    Glad to Be Alive
    scrape it
  1. 970g Scott Carbon Hardtail!!
    By LAN in forum Weight Weenies
    Last Post: 08-13-2004, 07:23 AM
  2. Replies: 1
    Last Post: 02-09-2004, 12:42 PM
  3. What is wrong with this picture?
    By notMurray in forum General Discussion
    Last Post: 02-07-2004, 10:35 PM
