What size clamp for seatpost????- Mtbr.com
Results 1 to 7 of 7
    Hip
    Hip is offline
    Reputation: Hip's Avatar
    Mine is 30.9. I dont see a 30.9 clamp listed....I see 28.6...31.8....34.9...
    Which do I get?? Or do i need to find a 30.9? I liked the Hope Quick Release and was going to get that.
    Is flexy
    Reputation: njhcx4xlife's Avatar
    30.9 is the size of the actual seatpost most likely. You need to know the diameter of the actual bike frame.
    Good People... www.efingersports.com
    Hip
    Hip is offline
    40mm top tube ovalized to 45mm at head tube, 35mm seat tube, massive D-shaped 28.6 seatstays & 31.8 chainstays with support strut.
    Im assuming its 35mm??
    Also...I am buying a stem...Mazzochi dirt jumpers are 1 1/8"????
    Is flexy
    Yes, it is 35mm and yes a DJ is 1 1/8".
    Hip
    Hip is offline
    Cool!!
    Quote Originally Posted by njhcx4xlife
    Thanks Man!!! Appreciate it!
    Ahahaha
    Oct 2007
    what sure your stem is the right size for your bars too
    25.4 or 31.8
    if you get a 31.8 or whatever and your bars are to small for it you can buy a shim
    Hip
    Hip is offline
    I got the 31.8...Thanks..
