What is involved in installing a chainguide?- Mtbr.com
Results 1 to 15 of 15
    customized
    Sep 2003
    Does it attach behind the bottom bracket flange? I have a 68mm shell on my bike with a 113mm spindle. The bottom bracket is good for a 73mm shell. Do I install the chainguide where the 5mm spacer would be?
    I've done the searches and can't figure out exactly how it installs. It will be going on a Azonic Saber frame.
    Any recommendations on which system to buy? I have a Raceface North Shore ISIS crankset.
    Louis
    T.Dot Represent
    Reputation: finchy's Avatar
    what kind of guide is it?
    fiiiiiiiiiiiinchizzzzzzzzzzle
    customized
    Sep 2003
    I was thinking about the Blackspire Dewlie.
    T.Dot Represent
    do u have ISCG mounts on ur frame?
    i have a e13 DRS that is being installed at my LBS today.... when i go to collect it i will take some pics of the setup so u can see how it works
    customized
    Sep 2003
    No mounts on that I know of.
    T.Dot Represent
    it will be sandwiched then between the bbshel and the frame
    if u have msn i can tell u more stuff on this
    add me if u do
    [email protected]
    Xtremely Moderate
    Reputation: e<i>o's Avatar
    The Dewlie looks like it sandwiches between the BB shell and BB flange.
    "Korash your enemiez, zee zem driven bevore you, and ear ze lamentation of za vemen"
    Former Noob Herder
    Reputation: zedro's Avatar
    Quote Originally Posted by Severum
    yes, that'll keep the spindle centered
    Quote Originally Posted by Gunslingger
    no doubt you must have majored in english or something rad!!!
    Reputation: flatulentfox's Avatar
    evil
    [Any recommendations on which system to buy?]
    get the e-13 (or evil, whats the difference BTW) DRS if you want to use a granny. if you ony want your middle ring, get the SRS. if you can do with out the granny, drop it. its soo much more simple and you have one less that to worry about adjusting/breaking etc.
    T.Dot Represent
    the only difference is the name. its the exact same company
    i would recomend the DRS over the Blackspre and MRP because of the stepped roller and the makrolon bashring
    Just Ride
    Reputation: zerossix's Avatar
    i love my mrp. i got one on my hardtail right now, thats sort of problematic setting it up orginaly and i still think im gunna cut through my chainstay eventually but other then that its awesome. never lost a chain...ever
    T.Dot Represent
    the single ring versions are good but... the dual has a wimpy thin bashring. it also doesnt have a stepped roller
    Just Ride
    real men only need one ring
    im gunna take some fire for that one.
    Former Noob Herder
    Quote Originally Posted by zerossix
    not from the real men tho...
    Xtremely Moderate
    I just put the e13 DRS on my Banshee and took her out for a spin today.
    It works puuurrfectly and its not noisy at all.
  1. Question regarding chainguide and bashring
    By upperbidwell in forum Specialized
    Last Post: 11-03-2004, 03:49 PM
  2. Tire knobs rubbing chainguide...
    By FoShizzle in forum Downhill - Freeride
    Last Post: 04-09-2004, 10:22 PM
  3. saint cranks and chainguide
    By [email protected] in forum Downhill - Freeride
    Last Post: 03-03-2004, 10:15 PM
  4. black bashring on evil chainguide?
    By axl in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-03-2004, 01:16 PM
  5. Chain ring suggestions for e.13 SRS chainguide
    By Gnar in forum Downhill - Freeride
    Last Post: 02-12-2004, 08:23 PM
