What is headtube angle usually based on?- Mtbr.com
    Dec 2004
    If you look at the Switch on the Rocky Mountain website, you'll find that one version comes with a 170mm fork, and the other with a 150mm fork. Both however have the same amount of rear travel and, of course, the same headtube angle. I always thought headtube angle was based on a built-up bike with fork. Rocky Mountian obviously doesn't do it this way.
    How do companies typically determine a frame's headtube angle? Is there any way to standardize the criteria?
    Former Noob Herder
    Reputation: zedro's Avatar
    headtube angles are simply the angle of the headtube vs the ground fully built up. Either RM didnt correct their figures for the different models, or the framesets are actually different and corrected to the particular fork do have the same angle for each model.
    Quote Originally Posted by Gunslingger
    no doubt you must have majored in english or something rad!!!
    This is a pretty common mistake...
    Quote Originally Posted by zedro
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    there are small hydro pumps at the top and bottom of the headtube that are scientifically designed to self-adjust to any terrain so the headtube is at a constant while the rest of the bike moves about......
  1. Fork rake/trail/head angle experiments
    By Walt in forum 29er Bikes
    Last Post: 10-23-2015, 05:33 AM
  2. Replies: 82
    Last Post: 10-27-2004, 12:48 PM
  3. Replies: 4
    Last Post: 05-03-2004, 06:52 AM
  4. How does a change in fork travel change headtube angle
    By RVM in forum Shocks and Suspension
    Last Post: 04-27-2004, 10:34 AM
  5. Question about headtube angle on the 575
    By ride red in forum Yeti
    Last Post: 03-27-2004, 11:27 AM
