What coil spring should I run on a 2007 dhx?- Mtbr.com
Results 1 to 12 of 12
    What coil spring should I run on a 2007 dhx? I'm 190 lbs without gear. I have been told that the older shocks had different recommendations than new ones and Santa Cruz recommendations were a little light. The 2009 recommendation from Santa Cruz says #450. That sounds about right. Please give me your input.
    Reputation: freeriderB's Avatar
    this might help...
    Quote Originally Posted by vontress
    Not sure which bike you are riding...but I have a VP Free that came with a 450# (recommended by SC because I am ~190 - 200 pounds in full gear).
    I have since switched to a 550# which Fox says is pretty much spot on for my weight. So I agree with your statement that says SC run a little light.
    I am on an '05 Heckler. What year DHX are you running? My shock is an '07 and I'm told it runs different than new shocks. Does that make sense?
    StraightOuttaCompton
    Reputation: Djponee's Avatar
    well, i am running a 500lb spring on my single pivot, and i am only 165lb.
    HARDTAIL PRIDE- 09 Kona Five-0
    Now I'm really confused. Does anyone know how to figure out what I need?
    Underweight Rider
    Reputation: AznRider's Avatar
    A friend of mine at your weight 190lbs on a 2006 heckler runs 450 x 2.35 and he says its a bit plush so my guess would be 500 x 2.35.
    Bike Hustler
    Reputation: LoozinSkin's Avatar
    it has everything to do with the leverage ratio of your suspension, your riding style and personal preference to suspension feel... not just your weight.
    Email the dudes at PUSH industries... they have a spring calculator and loads of experience solving these problems.
    SHAM-WOW
    Glad to Be Alive
    450 plush a little undersprung
    500 bigger hits
    For that bike you don't want to hit really big stuff so I would go the more plush route
    Dhx
    My DHX came on my new frame (December 06). I had it PUSHED in April of 2007.
    So I rode it stock for a full season of DH.
    I do not know why your 07 would "run different than new shocks" Not sure what this means.....
    2007 is pretty new. I'm not so sure the DHX has changed much from 07 - 08.
    Main thing for choosing a coil is making sure the length & stroke are whats required for the frame.
    Its got what plants crave
    Reputation: Jim311's Avatar
    Feb 2006
    Here's an idea... call Fox and ask?
    Reputation: bxxer rider's Avatar
    another opinion for you.... tf tuned spring calculator
    Quote Originally Posted by [Orge
    This problem could quite simply be solved if people would stop buying Konas.
    THELAND photographer
    Reputation: CdaleProph6's Avatar
    Quote Originally Posted by Jim311
    that makes too much sense! why would you call the company to ask
