UST Tire for Mavic 823?- Mtbr.com
Results 1 to 14 of 14
    huckit
    Just wondering what tires people are using for DH Race on the Mavic 823?
    Former Noob Herder
    Reputation: zedro's Avatar
    Michelins
    Quote Originally Posted by Gunslingger
    no doubt you must have majored in english or something rad!!!
    I wanna talk to Samson!
    Reputation: konabiker's Avatar
    while were on the topic of mavic ust rims, i have some questions. do you recomend using some sort of sealant(such as stans) or should they just hook right up? searched around and couldn't find that one out. will i still need rim strips?
    huckit
    Quote Originally Posted by zedro
    Michelins
    This may sound stupid, but do you have to use UST only tires on the 823's? Or can you use regular wire beaded DH tires?
    Former Noob Herder
    you can use regular tires...
    you dont have to use sealant but i recommend that you do.
    yeah, thanks. ill just throw in a little bit of stans. im still a little skeptical on the whole tubless thing, though. even though pinch flats are less likely with tubless, i just dont wanna get totaly f'ed over in the middle of the trail.
    Former Noob Herder
    Quote Originally Posted by konabiker
    its no different, you can use tubes if needed, which would only be needed if you shreded your tire. The sealant is there to seal tire punctures, not the bead.
    yep, im a tubless newbie. thanks for the help zedro.
    I've got the 823's w/a boatload of Stan's and regular
    tires and they lose air really quick. You can run regular tires, but I'd recommend going tubeless. Don't be skeptical-you can run lower pressure w/out the risk of pinch flats and less rotational weight-and much better traction.
    Former Noob Herder
    Quote Originally Posted by PattD
    yeah even the Maxxis USTs dont work all that well i've heard. Michelins are bullit proof as far as sealing tho, even running them flat they still can keep a seal
    so, is it true that mavic has taken notice to the durability issues of the 04 823s? im no wheel killer, never have been, but i've heard some bad stuff. i guess i should get along fine with my weight of 150lbs...
    Custom User Title
    Reputation: dpdsurf's Avatar
    Yeah, Michelins are the only UST tires I've used on my 823's that hold air without Stans. They are really tuff tires. I have the comp 24.1's soft.
    Former Noob Herder
    well there seems to be a design tweek on the 2005s, no firm word on the results. But if its the protos the pros were running this year it sounds very promising.
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    I'm running Mich. non-UST.
    I'm running non-UST 2.5 Hot S Michelins on 3 bikes and so is everyone else in the shop. We have rocks, cactus, and mesquite thorns out the whazoo, and these tires seem as reliable as any UST tire we've tried. The WTB Weirwolf non-UST models seem about as good as far as sealing also.
  1. stupid question from a new guy
    By micwan in forum Wheels and Tires
    Last Post: 09-25-2004, 06:04 AM
  2. Important tire question re: UST rims and non-UST tires.
    By homerjay in forum Wheels and Tires
    Last Post: 08-09-2004, 07:47 AM
  3. UST tire leaking from side wall!
    By Ronnie in forum Wheels and Tires
    Last Post: 07-23-2004, 12:47 PM
  4. Replies: 2
    Last Post: 05-18-2004, 08:11 PM
  5. Question for Shiggy (mounting non ust tire to ust rim)
    By SDtrailblazer in forum Wheels and Tires
    Last Post: 05-03-2004, 03:53 PM
