UST rim help- Mtbr.com
Results 1 to 9 of 9
Thread: UST rim help
    Bike Hustler
    Reputation: LoozinSkin's Avatar
    UST rim help
    Just got a used set of Mavic D3.1's and the seller sent them to me running non ust highrollers with XC presta valve tubes in them...
    I'm stoked on getting those tubes out of there ASAP but what kind of valve do I need to attach to get it happening? can they be picked up at a LBS?
    SUB QUESTION: the tires seem to have a hop in them, The rims are true and no dings but the tires themselves seem to be seated off center in some spots.. sup w/that?
    SHAM-WOW
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    You can check your bnike shop to see if they have the ust valve cores if you want them asap.
    Custom User Title
    Reputation: dpdsurf's Avatar
    Glad to Be Alive
    Mavic D3.1's are the first version of the 823's
    you can run non ust highrollers but use Stans...just reset the bead with soapy water
    presta valve you can get at LBS...you take off the tire and the valve fits inside the rim like you would run a tube....then it tightens down on the rim
    Boyeeee
    Reputation: BCBlur's Avatar
    I thought the 3.1 and the 819 were the same, not the 823.
    Custom User Title
    Quote Originally Posted by BCBlur
    You're thinking of the X3.1, the X I believe was for cross mtn which is now XM819. The D was for Downhill which is now EX823 for extreme or something like that.
    Boyeeee
    Cool. Now I understand why they changed the naming convention.
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    What was the X3.1 is now the xm819
    What was the D3.1 is now the xm823
    Loozinskin, you can actually make your own UST valve cores out of old tubes- you have to trim the rubber almost all the way off two sides to get them to sit inside the rim's center chanel. It works OK but it's a lot of fiddling, get the UST stems or stans and you're set. PS, windex works awesome (better than soapy water imho) for helping seat tires...
    Glad to Be Alive
    Quote Originally Posted by FM
    I like to........
    try some dishwashing soap around everything and the strait "jell" of the dishwashing (without water) around the tire bead
