Upgrading my bike- Mtbr.com
Results 1 to 7 of 7
    Oct 2007
    Upgrading my bike
    I have a 2001 gaint ac1 xtc, link to the bike on mtbr, http://www.mtbr.com/cat/bikes/bike-f...645_95crx.aspx
    I want to upgrade the suspension on it, get some newer shocks.
    i have a budget of around 700$ to spend on the shocks, i want to get a new front fork aswell as a new rear suspension, what do you guys suggest? im sure it matters about the riders weight too so keep in mind i am about 205 pounds.
    thanks in advance guys.
    Will to Win
    Reputation: albertomannil's Avatar
    Nov 2007
    700$ for both suspensions? you'r gonna have to check the classifieds.
    what fork is on there right now? and what travel front and back?
    Oct 2007
    Quote Originally Posted by albertomannil
    its a marzoochi bomber z1 drop off, 2001 model
    at least i think thats what the fork is.
    the rear shock is a rock shox, 6inch of travel i believe
    i was thinking perhaps ebay to purchase the parts?
    2007 Z1 for $300, then find out the eye to eye on your rear shock and upgrade that to whatever you want.
    http://www.teamcyclist.com/store/Mar...-RV_P14240.cfm
    StraightOuttaCompton
    Reputation: Djponee's Avatar
    2007 z1 and then get whatever shock you want cuz you will have 400 dollars left over.
    HARDTAIL PRIDE- 09 Kona Five-0
    Bombin trails in da 831
    Reputation: Cali*Style's Avatar
    Use this for the back... Super smooth, and I am a fat a$$.
    http://www.webmountainbike.com/foxvanrlrear.html
    For the front
    Marzocchi All Mountain 3 TST ForkpadMarzocchi All Mountain 3 TST Fork Coil spring system with air-assist top cap assemblies TST-2: Terrain Selection Technology 2-position compression + lock-up/out external damper settings 1-1/8" aluminum (Alloy-FR) pre-pressed steerer tube with 32mm alloy stanchions 1-piece forged magnesium, Monolite lower legs with 9x100mm quick-release dropouts: disc brake only (74mm/6" post-mount: max 8" rotor size) Cryofit M-design, boltless AM crown accepts 2006+ AllMtn Marzocchi fender kit (2.6" tire OK)
    Regular price: $439.00
    Closer to $800 and some change... Smooth set up for a budget rider and fairly strong.
    Doin what I do....
    Reputation: nickgto's Avatar
    Dec 2005
    You might want to consider this thing from WW:
    http://wheelworld.com/itemdetails.cfm?id=4200
    then just get a used TST-R
    DH:Mountain Cycle Shockwave 9.5 w/ 888R
    FR:Marin Quake w/ 888RC
    AM:BMC Superstroke 01 w/ 66RC2X
