Transition Revolution 36 Axle Swap?- Mtbr.com
Results 1 to 3 of 3
    Reputation: edray's Avatar
    Just got a set of these and the rear came set up with a 9 mil QR. I know I can swap it out for my 12mm but how do I go about doing so? Anyone have a set of these? Do I just pull off the cones and experiment or what? Any help would be great.
    El Pollo Diablo
    Reputation: SnowMongoose's Avatar
    Feb 2007
    I don't remember how exactly I did it, only that I did so without instructions, and it was a quick swap...
    based on how awful I am with a wrench, that should tell you that it's pretty easy, just play with how tight you crank everything (staying put vs spinning freely)
    TBC sell a axel for convert th 10mm hub to 12mm also when you bought that check if you have v1,v2, or v3 hub
