tire pressure for urban?- Mtbr.com
Results 1 to 8 of 8
    Reputation: NCBigHit's Avatar
    New question here. tire pressure for urban?
    I've been getting into urban stuff a little lately, stair gaps and such...I was wondering what pressures you guys run in your tires for stuff like that? Things feel much smoother when I'm running lower pressures, but after a pinch flat I went back up to ~50-60psi...which makes everything feel harsher. I'm riding a bighit, maxxis dh tubes, 2.3 roller pro tires, and I weigh 200 pounds. Thanks guys.
    I like to run my hook worms hard as hell. keeps from getting pinch flats.
    Team Captain
    i've put up to 80 psi in my hookworms but got scared after a few rides when i noticed the 65 PSI MAX written on the side... whoops! now they stay at 70...
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    Quote Originally Posted by NCBigHit
    yup, i run mine in the 65lb range............ anything less will pinch on stairgaps and whatnot
    New question here. How about Tubeless
    Quote Originally Posted by .WestCoastHucker.
    What if your running tubeless rims; like Ex 823's with 2.5's ????
    Pro Crastinator
    Quote Originally Posted by 9 Lives
    65lbs still = 65lbs. tubes or no tubes.
    not to mention, (all othe things being the same) after we throw down the mac daddy pinch flat, i will patch my tube, and you will still have a snakebite in your flat tire...........
    pretty hard
    You should run them low enough to get traction but hard enough not to pinch flat. I run 40psi in my Gazzis.
    ... and if we just ... Ok
    Well 45lbs is the max limit. That 45lbs = 45lbs. tubes or no tubes.
  1. Replies: 43
    Last Post: 03-09-2004, 08:26 PM
  2. Advice with Stan no tubes sealent ?
    By Johny Rotten in forum Singlespeed
    Last Post: 02-13-2004, 03:39 PM
  3. Front tire, rigid fork, about 2.3 & tire pressure?
    By winstonc in forum Singlespeed
    Last Post: 02-03-2004, 08:43 PM
  4. Rim width vs. tire pressure?
    By keen in forum Wheels and Tires
    Last Post: 01-22-2004, 10:03 PM
  5. Suggestions for WW FAQ section
    By Trevor! in forum Weight Weenies
    Last Post: 01-19-2004, 01:22 PM
