Tire Help- Mtbr.com
Results 1 to 5 of 5
Thread: Tire Help
    Go Fast
    Reputation: Datdude68's Avatar
    Tire Help
    I finally went to Diabo today and had a great time. The only problem I had was tubes kept puncturing. In all caught 5 flats. Can anyone give my some advice on how to prevent flats.
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    what kind of flats were you getting? at what psi? what tires?
    Go Fast
    __________________
    Snake bites
    Tires are IRC Back Country 2.25
    I know I need better tires
    Dont know what pressure
    Disco-Superfly
    Reputation: Jake_HT's Avatar
    If there is 2 holes, they are pinch flats, your tires have weak side walls and/or you are not running enough PSI
    Jake
    Yeti 303 WC 25th
    Quote Originally Posted by Dwight Moody
    Didn't you read the sticker on that shock? It said not to do whatever you did.
    Glad to Be Alive
    run higher air pressure
