Tire Choices...Please Help- Mtbr.com
Results 1 to 8 of 8
    Reputation: edray's Avatar
    Caution;  Merge;  Workers Ahead! Tire Choices...Please Help
    I need new front and rear tires for my bighit. The front was a Maxxis 2.7 Minion, but now it rubs on my new fork so needs to be switched out. The rear is a 24x2.7 Maxxis High Roller and needs to be swapped out because it has some pretty large gashes in the sidewalls. Im looking to replace the rear with a 24x2.5 Kenda Nevegal Stick-E and the front with a 2.5 Maxxis High Roller 60 Duro. Will this combo work. I know that Kenda runs a bit big. If im off at all with these choices please correct me. Any help would be awsome.
    PS: Ill be riding at Diablo, so its rocky, pretty dry and hard pack most of the time..
    Thanks alot
    Erik
    Disco-Superfly
    Reputation: Jake_HT's Avatar
    Quote Originally Posted by edray
    Thanks alot
    Erik
    I Can't help you with your tires, but I can help you by bumping. I'm sure somebody here knows what you need help with.
    Jake
    Yeti 303 WC 25th
    Quote Originally Posted by Dwight Moody
    Didn't you read the sticker on that shock? It said not to do whatever you did.
    Bum Buzzer
    Reputation: Huck Banzai's Avatar
    May 2005
    Thanks alot
    Erik
    Kenda 2.5 is about the same as a Maxxis 2.7.
    Nevegals front and rear would hbe superb.
    Otherwise 2.5 Mobster front, 2.5 High roller rear is a nice setup for a variety of conditions; use a sticky in the front and a 60 in the rear as a compromise.
    Diablo likes Minions as well.
    There are alot of options; volume is often a preference ( I like 2.5+ for creek 2.2-2.3 for the Kill..)
    Any specific type of terrain outside of diablo you want to ride? Are you smooth or a plowboy? Do you ride often or infrequently? How often are you willing to spend $$ on tires......
    these types of questions make answers more specific!!
    Fort Valley = Gnarl Fest
    Reputation: Jekyll_Jockey's Avatar
    Any consideration to a Minion 2.5?? If you like the tire why not just down size. I run a Minion 2.5 up front and a buddy runs the 2.7, there is no noticable differance except his shed mud much better.
    And I keep my larger width tire up front, keeps the bike feeling more nimble. Good Luck
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    I agree with HB run the ST front & 60 rear.
    Reputation: shiggy's Avatar
    Dec 1998
    The Syncros BHT tires are worth looking at.
    https://www.syncros.com/tires.htm
    They are made by Kenda. Use a sticky compound but the rear is slightly harder for longer wear. They do offer a 24x2.50 rear. Not overly costly.
    mtbtires.com
    Glad to Be Alive
    I personally don't like the Highroller in the front.....I prefer the Minion ( IMO it tracks better in the turns.
    rear tire I liked the high roller
    Juanjo
    Reputation: EastCoastHucker's Avatar
    Jun 2005
    IMO the Minions are one of the best tires for DH, I run 2.7 ST front and rear and can't be any happyer...
    ~~~~~~~~~~~~~~~~~~ \m/>-<\m/ ~~~~~~~~~~~~~~~~
    Jesus loves you ............. Everyone else thinks your an A$$hole .
