Tire cancer...- Mtbr.com
Results 1 to 21 of 21
Thread: Tire cancer...
    Disco-Superfly
    Reputation: Jake_HT's Avatar
    Tire cancer...
    My tire (Kenda Kinetics) has grown a little bubble on it. It is by the rim, and I dont know how it happened. I do have patches on my tube, put when I took the tire off the bubble is nowhere near any of the patches. The bubble is about 3/4" wide and tall; It sticks out about 1/2". I run my tires at 55 PSI, and the tire max. is 65 PSI.
    Should I stop riding it incase it rips right off or something?
    Get a new tire? (I don't have money)
    Or just stop worrying about it and ride.
    Sorry for no pics, but I think you can picture it in your head.
    Jake
    Yeti 303 WC 25th
    Quote Originally Posted by Dwight Moody
    Didn't you read the sticker on that shock? It said not to do whatever you did.
    kona-tize me captain
    Reputation: austinb89's Avatar
    thats weird
    have u left ur bike out in the sun for a while? does the bubble deflate when u take out pressure in the tube?
    Looking for a 7.87 x 2.25mm shock, any brand any age that runs well!! cheap would be appreciated!
    Reputation: RobsterCraw's Avatar
    sounds like the end of that tire. Bubbles/lumps are usually a bad thing.
    Disco-Superfly
    Quote Originally Posted by austinb89
    I bring it in everytime, so not left in sun.
    It goes away when I deflate it to about 10 psi and under (after I push the bubble in)
    Jake
    Yeti 303 WC 25th
    Reputation: freerider167's Avatar
    Dec 2004
    Quote Originally Posted by j_a_k_e_69@hotmail.com
    it might have been stretched out when you hit something. maybe it's a weak spot, i would just try to keep the bubble in or just ride till it dies.
    Disco-Superfly
    Quote Originally Posted by freerider167
    it might have been stretched out when you hit something. maybe it's a weak spot, I would just try to keep the bubble in or just ride till it dies.
    Probly was stretched out on a weak spot.. there is no way to keep the bubble in, so I am just going to have to ride it till its done. I hope it doesnt cause injury.
    The tire was new in march.....
    Stupid Bubble.....
    Jake
    Yeti 303 WC 25th
    That's weird
    I had the exact same thing happen to me a coupla weeks ago with a Kenda Kinetics tyre. I was at a reasonable pressure and going fairly hard and steep. I chucked the tyre and got a new one. I didn't like the look of it at all.
    Disco-Superfly
    Quote Originally Posted by Panacea
    No more kenda kinetics for me then.....
    Jake
    Yeti 303 WC 25th
    Duct tape it maybe?
    If you can't afford new tires and they are still in good condition (other than the bulge of course), you might be able to salvage it with some duct tape on the inside.
    Duc
    Disco-Superfly
    I put the part of my tube that has a patch on it directly under the bubble.... It helped some but that retarded bubble is still there...
    Jake
    Yeti 303 WC 25th
    Reputation: MicroHuck's Avatar
    Jan 2005
    Quote Originally Posted by duc135
    Duc
    I agree. 7 layers of duct tape on the inside of the tire will do the job. The bulge will still be visible but at least the inner tube won't pop out and burst.
    I rode a tire with a 1 inch long cut in it for several months. I put many layers of duct tape on the inside and it held up fine and never bursted. Just make sure to cover it with duct tape at least two inche on all sides to prevent the duct tape from coming out too.
    I liked the old *****
    As mentioned, the duct tape will work - longer than I ever thought. Keep an eye on the sidewalls, as you may get more.
    This happened to me with the older version Mich Hot S. I called Mich and they recognized the problem, had already made changes to manufacturing (claiming some new feature), and sent me 3 replacement tires (after sending them sidewall cutout of brand).
    The cause for me was lots of side rub on rocks. It just wore out the [thin] sidewalls, and happened to the tire on rear much more so. I wouldn't expect the Kenda tires to be nearly as bad as my experience - may be worth giving them a call.
    Roll some duct tape around your pump. You'll have some on the trail if it happens again. Make sure you clean the inside of tire before applying tape, as all will push through with pressure that high. It did for me in the 32lb range. If on trail, apply tape (to clean tire), rip it off and apply a few new layers.
    You should be able to get some more life out of it . . . Good luck.
    Disco-Superfly
    Tire exploded today......... 5 layers of duct tape, WITH the patch in the same spot....
    blew a hole through the tape and patch....
    I went off a 7 foot drop to rough tranny and about 30 seconds after I landed it exploded.... Nice and loud too.
    No more kenda's for me
    Jake
    Yeti 303 WC 25th
    Dec 2004
    woah, that must suck man, i bet it was a weakspot. see if you can get a replacement or get some maxxis. i love maxxis ttires.
    Disco-Superfly
    I would sport maxxis highroller but dont have the cash..... Im using my sucky old wore out specialized tire now...... I hate it
    I still dont understand why it would just form a bubble for no reason....
    I was really liking the kenda too...
    Jake
    Yeti 303 WC 25th
    Dec 2004
    never had a kenda and the specialized tire(05 enduro model) wore out within 2 months and i didn't skid. i think that kenda might have been defective, you should email them and tell them what happend and see if you can get a new one free
    Disco-Superfly
    Email was sent.... I hope I get a free tire, I wasnt bad mouthing them so we will see how it goes. The tire was bought 2nd hand, but it wasnt used..... 2nd hand or not, no tire should explode.
    EDIT: wow, surfing the site I found this:
    Kenda Kolossal DH
    2.35" and 2.6" CAP Ply casing helps prevent punctures and slices
    Ramped knobs with tie-bar technology.
    Aggressive braking and cornering knobs.
    ****** CLOSE OUT ******
    SPECIAL PRICE $5.00 / each
    STANDARD F/R 24x2.60 Wire 40-65psi 1085g $5.00
    STANDARD F/R 26x2.35 Wire 40-65psi 1120g $5.00
    STANDARD F/R 26x2.60 Wire 40-65psi 1205g $5.00
    STICK-E F/R 26x2.60 Wire 30-50psi 1205g $5.00
    STICK-E F/R 24x2.60 Wire 30-50psi 1805g $5.00
    Jake
    Yeti 303 WC 25th
    Disco-Superfly
    whatI said:
    I have a kenda kinetics 26x2.35 front tire. I have had it since early
    march 2005. I bought it new from my friend. I have had a problem with a
    "bubble" on my front tire the past few days. I run it at 55psi, and the
    max is 65psi. Just today, my kenda tire and kenda tube exploded. The
    hole is about 3 inches wide on the sidewall where the bubble was. I did
    expect this, becuase of that bubble on the tire, but I dont think that
    bubble should have happened in the first place; especially not on the
    front tire. I really did like the tire alot. I think this was definatley
    a defective tire. I do not expect a new free tire; but it sure would be
    nice, becuase I have no money for a new one.
    What they replied: ( only 2 days wait pretty good )
    Jake,
    Thanks for your email; regarding your Kinetics tire problem; are you
    using sealant in your tires? If so please contact me, my info is below.
    If you could also send me some digital pictures that would help expedite
    the warranty process. Feel free to email me if you have any questions or
    problems. Take care.........Mike
    I am taking pictures today.... rest of story later....
    I will be stoked if they give me a new tire for free
    Jake
    Yeti 303 WC 25th
    Disco-Superfly
    ... and if we just ...
    Props to kenda!!.... They are sending me a new tire for free
    I am stoked.....
    Jake
    Yeti 303 WC 25th
    Dec 2004
    I am stoked.....
    congrats!!, did you need to send your old ones back?
    Disco-Superfly
    Nope, just a few pictures, and now a new one coming.... more props to kenda...
    Jake
    Yeti 303 WC 25th
  1. Replies: 24
    Last Post: 01-02-2010, 07:31 PM
  2. Tires at MEC
    By turbo ultrasport in forum Eastern Canada
    Last Post: 12-04-2004, 04:00 PM
  3. Blur rear tire choice thread from old boards
    By CraigH in forum Santa Cruz
    Last Post: 03-03-2004, 05:16 PM
  4. Advice with Stan no tubes sealent ?
    By Johny Rotten in forum Singlespeed
    Last Post: 02-13-2004, 03:39 PM
  5. Suggestions for WW FAQ section
    By Trevor! in forum Weight Weenies
    Last Post: 01-19-2004, 01:22 PM
