Tightening brakes + Pic's- Mtbr.com
Results 1 to 13 of 13
    Reputation: leddder's Avatar
    Hey I noticed my brakes have slowly gotten less sensitive, I have to pull it a lot further back to get the same braking power. And now I when im dirtjumping I can't tighten my brake hard enough to stop my pedals from moving during one footers.
    So is there any way i can get the same sensitivity back?
    here are some pics of me and my friends riding...
    heres a picture.. this is what I have to do when its rains for 30 days straight in seattle...
    <h1>::edit:: They are Hayes hydraulic brakes, im not sure wich model they are ::edit::</h1>
    Here are some pictures of the brakes...
    The 3rd Planet is sure that they're being watched by an
    eye in the sky that can't be stopped
    Reputation: skatetokil's Avatar
    what kind of brakes? either you need to adjust them for worn pads or you need to bleed the system.
    kona-tize me captain
    Reputation: austinb89's Avatar
    cool pictures man, you probly just need to bleed your brakes. im in the same situation im just scared to bleedf them though
    Looking for a 7.87 x 2.25mm shock, any brand any age that runs well!! cheap would be appreciated!
    T.Dot Represent
    Reputation: finchy's Avatar
    bring it to the LBs
    get it bled
    problem solved
    fiiiiiiiiiiiinchizzzzzzzzzzle
    Meh.
    Reputation: XSL_WiLL's Avatar
    Hayes HFX Mag G1. You probably need to have them bled. The reach adjuster on the Hayes brakes tend to back out after a while. Try dialing in the reach first. It's the 2mm allen bolt by the knuckle of the lever.
    do you suggest bleeding them by myself?
    or would it be worth it to take it to the lbs?
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Bleed system & blue lock-tite on the reach screw.
    just check the little 2mm screw. if that doesn't fix it bleed them.
    Glad to Be Alive
    before bleeding them ...just re-set your pads....take your tire off then brake pads....push in with a 10mm wrench...then put pads back on and tire...press brakes and then re-set levers...if that doesn't work then bleed
    T.Dot Represent
    if u do need them bled just pay the lbs to do it that way u wont mess up a very expensive part!
    Reputation: canada17's Avatar
    careful with the blue locktite
    Careful with the blue loctite on the reach adjust. The heat from the fluid on a long descent can heat the piston and re-melt the loc-tite. It can flow down into the piston/plunger causing all sorts of problems. if you really want to stop the adjust from moving use the white teflon thread tape. Won't melt will hold like hell
    "Eagles may soar, but Weasels don't get sucked into jet engines"
    Reputation: Smiffman's Avatar
    Jan 2005
    I disagree if You think got the right stuff to do it with (syringe, correct oil and a bit of concentration) give it a go that way you'll get to understand how it works a bit more. Then if all else fails go LBS as any damage you can cause will be reparable. Give it a go- you might save yourself a bit of money in the process.
    smw
    smw is offline
    pedal pusher
    Reputation: smw's Avatar
    Jun 2005
    Sounds like the pads a worn and need to be changed.
    Sean
    Gears and suspension are for girls and old men. Feel free to quote me in your signature. - Fast Eddy
