Ti Mounting hardware for Fox DHX 5.0- Mtbr.com
Results 1 to 9 of 9
    Reputation: juanbeegas's Avatar
    Oct 2007
    I've been searching around, but can't find any mention on Ti mounting hardware for a Fox DHX 5 air shock. Do they even exist?
    Reputation: 006_007's Avatar
    Quote Originally Posted by juanbeegas
    Are you talking about the through bolts, or the reducers?
    Oct 2007
    Pretty much whatever mounting hardware there is available for mounting a Fox DHX 5.0 air is welcomed. If I could get the bolts, the reducers, the whatever...
    Living Ghetto Fabulous!
    Reputation: Uncle Cliffy's Avatar
    Ti bushings don't exist AFAIK, but why would you want that anyway?
    For the bolts, check for your size here.
    Quote Originally Posted by kidwoo
    The internet sounds like a tough place to ride.
    Quote Originally Posted by Uncle Cliffy
    Bling would be the only reason I could see. Al bushings will be lighter then Ti ones.
    I would not run Ti mounting hardware for my shock - Steel is nice and bendy. Ti will just break.
    Oct 2007
    It's just a little experiment and I want to see just how far I can go with this. Thanks for the help, guys.
    Dec 2008
    A worthy experiment. You will save a bunch of weight. I have used the same Ti/Al nut shock mounting hardware on my DH bike for the last 2 years. If your suspension is set up properly and you don't ride like a bowling ball you shouldn't have any problems. I got mine here...
    http://stores.shop.ebay.com/Jersey-C...34Q2ec0Q2em322
    Cliffy may have been getting at it with checking the size, the the mounting bolts are the only thing you will possibly be able to find in Ti, and mounting bolts are frame specific, not shock specific.
    I had seen someone on ebay that had Ti mounting bolts for a V10 and VP Free (different seller than QSBS' link)
    Oct 2007
    Hey, thanks guys. I'm just going to look into just the bolts for the time being and see what I can get from my own local supplier.
