Is there a DH BB that doesn't suck a$$?- Mtbr.com
Results 1 to 20 of 20
    After reading through the reviews, it doesn't seem like ANY of the DH BBs or cranksets are good at all.
    IS there anything out there that's decently priced and holds up well?
    I honestly had better luck with my Shimano UN BB and square taper cranks, which lasted two years of riding hard in muddy trails, before bending a crank from landing a 6 footer straight into a boulder. BB was still smooth as budda. My Truvativ DH cranks and BB didn't last more than 3 months at best. The BB was crunching after just 1 month.
    Meh.
    Reputation: XSL_WiLL's Avatar
    ISIS sucked - teeny tiny bearings. Octalink held up pretty well.
    Outboard bearings last if the frame is prepped and the BB/cranks are installed correctly. I like Shimano cranks the best. The spindle/arm interface doesn't wear out everytime you install/remove the arm.
    Are Saints or Hones a good bet? I don't go over 7 footers, so the Hones are looking tempting.
    Thanks for the info.
    I'm running Shimano cranks (XT and Saint) and Shimano outboard bearings and never had a single issue; not even after 3 years of abuse.
    Quote Originally Posted by ender
    What type of riding are the Hones for?
    Are they in between Saint and XT? or is XT better.
    I can get the Hones as a complete w/BB for $130 brand new, which sound like a killer deal.
    Capricious youth...
    Reputation: Prettym1k3's Avatar
    ISIS sucked?
    I've been running the same BB on my 7point for over 2 years, and I do everything from 15 mile XC rides to Northstar and and Downieville runs on that bike.
    Sure, the BB is toast, but it still spins like it's brand new. Just makes more noise now.
    Meh.
    NICE KID...NICE
    Reputation: wookie freeride's Avatar
    Saints and Hones Rock
    Either will last you a long time...And if you break a set of the saint, The broken set of cranks will be your last worry.
    "At that point man, your just riding your bike."
    Transition
    Pedalshop
    Quote Originally Posted by wookie freeride
    Cool looks like I'm going with the Hones.
    I've never used the One piece Crank/Spindle types before. It is possible to adjust the chain line with them? I noticed you can buy them in crank length, but no options for width, I'm guesing one size fits all?
    This is for a Reign x1.
    Is flexy
    Reputation: njhcx4xlife's Avatar
    Quote Originally Posted by Dirt_Dog
    They give you these snazzy little spacers to adjust the chainline slightly and it also allows it to fit both bb sizes. If you have serious problems lining things up with the supplied instructions (which are pretty good just make sure you have a park BBT-9) you can move the spacers to the other side of the bb shell to shift things around.
    Good People... www.efingersports.com
    hey, ive had the same UN bb on my klein mantra for 8 years! started to creek and it ended up just being that the whole thing was really loose, so i tightened it and no more creek.
    anyways, i bouhgt a set of square taper cranks for my stinky im building up and will definatly be buying another shimano UN BB
    Equal opportunity meanie
    Reputation: DHidiot's Avatar
    I run Saints on my DH bike and Hones with the beefier spindle on my 6" bike. They are both a breeze to remove and I have never EVER had one of them loosen or had a BB fail. As someone else mentioned, the lack of a press fit does a lot for the longevity of the system. As I always say, Shimano nailed it with the brakes and cranks and kinda seemed to flop everywhere else.
    805
    Glad to Be Alive
    I went through a bottom bracket in one season...thanks to the North Shore wetness
    But still will always recommend Saints
    eci
    Reputation: snowskilz's Avatar
    i have had very good success with shimano and fsa outboard bearing BB's.
    I have had bad issues with fsa and truvativ isis bb's.
    Perpetual Hack
    Reputation: mykel's Avatar
    Honing Up on specs
    Careful on the Hones.
    There are two versions, one is a three ring XC, the other is a 2 ring + Bash AM/FR. The two ring has a tougher spindle as well as steel pedal inserts.
    michael
    Waiting for Godot
    Reputation: OilcanRacer's Avatar
    Quote Originally Posted by mykel
    michael
    what he said. also if your over 190lbs hones might be a little weak if you do big drops.
    i just put some on my new dh bike. a good choice in my opinion
    Out riding, leave a message
    Reputation: rustyskills's Avatar
    Quote Originally Posted by DHidiot
    i'd have to agree with this statement
    Reputation: his dudeness's Avatar
    I haven't really yhad any luck with FSA or Truvativ outboard bearing BB's. They seem to last a few months and then they start feeling notchy. I don't have any experience on Shimano's outboard bb's for mountain bikes, but they are t!ts on the road bike.
    Saints will do the trick.
    as others stated.. if they bust.. thats the least of your worries.
    Quote Originally Posted by DeanH
    I went with the Hones (@ $130), since I don't do any drops over 7 feet and have long-lanky legs for extra suspension.
    Thanks a lot for the help guys!
    Saint is the crank i think .. gravity makes good one too ... it depend on how often you crash and how big you go ... but Saint should be your best choice ..
