Switching to 24" rear - how much slacker will it be?- Mtbr.com
Results 1 to 5 of 5
    Mar 2005
    I'm thinking of switching my kid's DH bike to a 24 inch rear wheel to gain a little standover height.
    I do know the trade-offs to expect with the change--I definitely know the downsides.
    The slacker angles will probably be ok still, even so I'm wondering how much they will change.
    Anyone have any thoughts?
    Mar 2005
    1-1.25 degrees more slack.
    Mar 2005
    Quote Originally Posted by phatfreeheeler
    Thanks - I was thinking that it would be in that range;
    I'm also wondering if it changes the seat angle more than the head angle, or if the effect is about the same on both.
    Visualizing it, I would think it would either be the same change or affect the seat angle more, but I'm not sure
    seat angle may kinda depend on your linkage. But with you off the bike it should be about the same as your headtube
    Turner DHR
    My threads are typically awful. Thanks for putting up with them.
    Glad to Be Alive
    how tall is your kid
    ...maybe switch both front and back to 24 inch to have better overall geometry
    you will have to adjust the seat a little if you run 24 inch on rear alone
