Sunn Radical SIZE HELP!!- Mtbr.com
Results 1 to 5 of 5
    im 183-184 cm tall
    inseam 86cm
    what size short long? plz help
    Good price on the short
    i had a small radical, which fits me well, but i am 1,71m , with 1,84m you should go
    for the large, sorry
    Reputation: Hirvi's Avatar
    Oct 2007
    Go for a long, absolutely. I'm 190cm and the long one is fine, wouldn't mind if it was even a bit larger. The reach is around 400mm, and the small is an inch shorter.
    Retarded!
    Question for you Radical owners:
    What type of ISCG does this frame use? Any photo I've been able to find of the frame shows only a single hole next to the bottom bracket, and the BB flange has some sort of stepped notch in it.
    Reputation: PeterWest's Avatar
    Quote Originally Posted by airlobb View Post
    im 183-184 cm tall
    inseam 86cm
    Medium Giant Glory
