Sun Double Track or Mavic EX729??- Mtbr.com
Results 1 to 13 of 13
    ...idios...
    Reputation: SteveUK's Avatar
    I'm about to get a wheelset built up around Hope Pro 2 hubs but can't decide between the Double Track's and the EX729's. I'm riding a pair of 729's on DMR Revolvers at the moment and have no complaints, so would have no problem going with the Mavics again, I just like the aesthetics of the Double Track. Weight isn't an issue, I'm just looking for some idea as to the comparative differences, if there are any of particular consideration. The bike is built on an '07 Big Hit frame, my riding is freeride and split 60/40% urban/trails, so there's quite a lot of square-edge stuff and unforgiving landings when I get it wrong (which I do with some regularity), although I'd consider myself to be a fairly smooth rider most of the time.
    Is the Double Track a worthy contender? Or do I stay with tried and tested?
    Many thanks in advance for your help.
    Diogenes
    Meh.
    Reputation: XSL_WiLL's Avatar
    Go with the 729s if you haven't had any issues. The Double Track may be strong... but it is MUCH heavier.
    Glad to Be Alive
    double tracks (the Sun Mag 30) are really strong rims, but they are heavy,......you say you do not care but weight but it does matter.....if you are building...why don't you go tubeless with823's
    ...idios...
    "if you are building...why don't you go tubeless with823's"
    I've no experience with tubeless. How would my tyre choices affected? Any other considerations?
    Meh.
    You can still run tubes with the 823s if you'd like. Most non-UST tires can still be used as tubeless with a bit of Stans.
    Glad to Be Alive
    Quote Originally Posted by SteveUK
    you need a air compressor and some stans no tube juice....mount 1/2 of tire and add 2 scoops of stans......then fully mount tire......take soam soapy water (car wash/dish soap) and wipe rim and bead of tire.....then fill up with air.......good luck....michelin tires work the best
    General Rabble-Rouser
    Reputation: Karupshun's Avatar
    I built a set of 729s over christmas. I still need to weigh them. I'll try to post tomorrow.
    DT comp spokes, alloy nipples Ringle Abbah front hub and a generic rear 12x135
    It was going to be Hope Pro II, but the blue ano was back ordered
    Very light, crazy stiff.
    Doesnt the Double Trac weigh 800g for the rim alone?
    Reputation: rustyskills's Avatar
    GO with the Mavic
    Reputation: his dudeness's Avatar
    Mavic's tend to build up easier and require less truing in my experience. If you are building the wheel yourself go for the 729. They're burly and they build up really well.
    moaaar shimz
    Reputation: tacubaya's Avatar
    Mavic 729 is da bomb
    N* Bomber Crew
    Reputation: Raptordude's Avatar
    729's are boss.
    Sun Double Tracks/Mag 30's are just ridiculous. If you need wheels that strong, you need to reconsider your riding abilities.
    Northstar 2008 Riding Crew
    StraightOuttaCompton
    Reputation: Djponee's Avatar
    or stop hucking fat bender cliffs to flat and landing front wheel first.
    HARDTAIL PRIDE- 09 Kona Five-0
    N* Bomber Crew
    Quote Originally Posted by Djponee
    Yeah for real. I see reviews for the Double Tracks that say: "These are tough rims...I've cased like 10 times and they're perfect!"
    Solution: Do not case jumps.
