Stuck Powerlink- Mtbr.com
Results 1 to 6 of 6
Thread: Stuck Powerlink
    Reputation: Majestix's Avatar
    Stuck Powerlink
    Soo I do like nomal and untension the chain the slide the 2 pieces different ways on my pc99 sram chain but its not moving...umm...is there any advice on a stuck powerlink? lol
    Jm.
    Jm. is offline
    Reputation: Jm.'s Avatar
    They seem to get "jammed" together at least half of the time. Skinny needle nose pliers are what you need. The "no tools required" think is kind of a farce. More often than not they don't just "come apart" for me.
    I know in my heart that Ellsworth bikes are more durable by as much as double. AND they are all lighter...Tony Ellsworth
    haha i had to use my chain tool on the adjacent pins to loosen them a bit then degrease it and use some plyers...but its off lol...now its loose
    Apr 2005
    Channel Locks
    I work in a shop and when we have to take SRAMs off for cleaning a pair of channel locks works the best. I have never ruined a quick link and an 8 inch pair has always done the trick. (Squeeze on the diagonal). Also you get a better bite than with a pair of needle nose pliers. Although needle nose will work.
    Just Ride
    Reputation: zerossix's Avatar
    needle nose pliers and some patience. usually takes a few tries.
    Bum Buzzer
    Reputation: Huck Banzai's Avatar
    May 2005
    Ive never had any problem removing the powerlinks by hand, been using PC-59's for years (99 is a waste IMO for FR/DH - what, save 10g? lol)
    you need to press the chain together (compress laterally) and then push th elinks together. I did however have one magically eject and leave my chain on the ground (fortunately while I was stopping, found the chain 10' back, never spotted the PLink.)
    The KMC links are hard to get apart even with pliers!! Some company makes a tool for sperating them, I cant recall the brand, but if I recall I will post it!!!
  1. Freakin' Powerlink...
    By PC1 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-17-2005, 04:37 PM
  2. SRAM powerlink failure
    By chuffer in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-24-2004, 05:55 PM
  3. SRAM powerlink weakening issue
    By laxguy86 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-19-2004, 05:33 AM
  4. Using SRAM PowerLink? Try a ConneX!
    By jennasdad in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-08-2004, 09:57 AM
  5. HELP...MX Pro ETA rebound adjustment stuck.
    By Disaster in forum Shocks and Suspension
    Last Post: 02-11-2004, 01:10 PM
