Strongest AM Frame?- Mtbr.com
Results 1 to 30 of 30
    Strongest AM Frame?
    Coming from a DH DJ and BMX background, I am looking for a AM bike that can take jumps and has a rear end that is strong. Figure I would post here to avoid any 29erism BS.
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    simply strong doesn't equal a good bike at all. you need to consider suspension and geometry as well. give us more parameters to work with...
    Looking for latest geometry, 66 head angle or so, great climber and descender. My Trail bike for years now has been a 575, but it is time for something burlier. I have been thru frames and a couple rear ends. I ride it hard like DH bike, jump it like a DJ. Looked at the Banshee Rune, not sure yet. Was thinking of building a lighter FR bike, but I want to still climb everything with it.
    I talked with Carter from Blackmarket Bikes at the last Sea Otter, His new A\M bike is supposed to be super strong, don't see any feedback out there on how they ride though...
    Check out the Canfield The ONE. I have mine set up with 66 deg, 7" travel in the front and 8" in the rear. Climbs like a mountain goat, but going back down is just like a DH bike.
    Riiiiiide...
    Reputation: PsyCro's Avatar
    VTT CAMINADE ONE4ALL VELO FRANCAIS | CAMINADE
    This one has peaked my interest lately. 'Steel is real', lifetime/transferable warranty, and specs are pretty much spot on...
    Obviously no one is gonna have ride time or long term experience, but in my book, this is amazing and is the kind of AM frame i'd like.
    Pro Crastinator
    canfield was going to my first suggestion as well...
    Aug 2010
    Pretty sure you need a Canfield One. From what I gather it is a true ONE bike option.....plus it looks sick as well.
    Reputation: rustybkr's Avatar
    Re: Strongest AM Frame?
    +3 on the One...everything you want.
    Rage43, How is your gearing set up?
    I saw a Canfield build online from Aug '13 with a hammerschmidt and thought that might work for me. I am coming from a 3X9 setup now and really like my range. 20-32-44 and a 11-34 cassette gets me up any hill (22% grade on my local) and can haul ass down.
    Glad to Be Alive
    Canfield The One hands down......it can take a licking
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    1st generation Knolly Delirium T.
    Reputation: jimw's Avatar
    Specialized Enduro Expert Evo. Mike Montgomery was running one at Rampage (with different fork and many other changes, but same frame), and it climbs, well, like a heavier Enduro. I ride mine anywhere and everywhere. More thoughts here.
    Reputation: charging_rhinos's Avatar
    + 12,326 on the Canfield One. I've ridden mine very hard, both up and down. It has a very rigid feel to the entire frame, and it feels very light and nimble. Buffalo with ballet slippers. Jumps well, climbs better than anything in its class, and really does feel like a dh bike when going down. I've got a 1x10 drivetrain (28T, 11-36) and it will climb pretty much anything. If it were available at the time, I would have probably gotten Canfield's 9T microdrive rear hub, as it would give me pretty much the full range of a 2x setup, but I don't miss the little bit of top end I've lost. I have found i really don't miss it much at all. It just rips. Weighs in at around 34lb, and outperforms my 30lb Reign both going up and coming down. SUPER fun bike, and the company is incredibly good to deal with.
    tangaroo: What electrolytes do chicken and turkey have again?
    rck18: All of them, because they're meat.
    If you want a bomb-proof bike like you're used to from DH and DJ, make sure to get an Aluminum frame. Much more damage tolerant than carbon. I'd recomend a Specialized Alloy Enduro (EVO or regular).
    bike rider
    Reputation: Lelandjt's Avatar
    There's two ways this could go and depending on your intent a freeride bike that can climb or an Enduro/Trail bike that can handle some abuse is the answer. Will you be using it to pedal up to backcountry descents where it has to be just good enough at climbing to make it tolerable but then provide a near-DH ride on the way down? Or, will you be using it as a Trail/XC bike where it needs to be pleasant on rolling terrain and flats?
    If the former, a 7" bike that pedals reasonably and has room for a long seatpost (Canfield One) would be killer with a Fox 180 TALAS.
    If the later, you'd be better off with a 150-160mm bike. Nomads seem pretty durable and designed for that niche.
    Keep the Country country.
    Jan 2013
    Quote Originally Posted by .WestCoastHucker. View Post
    +1 for canfield. It's exactly what you are looking for...
    Quote Originally Posted by guitarjohn21 View Post
    I have a 28t drive and a C2 Micro drive rear hub with a 9-36 cassette. LOVE the range with this! And a tip; the ONE's suspension design is to eliminate bob from pedaling forces in the granny gear. If you run a 2x setup you will notice a big increase in pedal efficiency when you drop down to the climbing gear. I decided on the 1x because I could use a 28t drive to gain the pedaling efficiency combined with the 9t rear makes up for the high end that I would want for the descending. I think this drive train is perfect for this bike.
    Get a Knolly Delirium.
    Jan 2009
    knolly chilcotin.... or canfield theone.
    Quote Originally Posted by Lelandjt View Post
    It has to climb well. I was originally looking for a strong 6" bike. It seems most are made to be as light as possible and lack the strength I need. The FOES FXR looked pretty solid, but I don't know anyone who has any time on one. A 7" Bike that climbs would be a dream. I do climb a LOT, so that is very important in this decision.
    I have been riding a '10 575 as a trail bike, and it is not considered the best climber, but I am real happy with what I can do with it. It gets up real technical climbs well, and is a great descender. Just bent the frame again, just enough where the rear tire almost rubs. Need a bike where I can forget about baby-ing it. This Canfield sounds great.
    Professional Troll
    Reputation: Gemini2k05's Avatar
    Apr 2005
    Quote Originally Posted by JefedelosJefes View Post
    Just...stop, now, please.
    May The Force Be With You
    Reputation: shwinn8's Avatar
    Feb 2006
    old school Santa Cruz Bullet?
    '16 Balance
    '11 Jedi
    '08 Toyota FJ Cruiser / Facebook: NyNomadFJC
    Delirious Tuck
    Reputation: thefriar's Avatar
    Knolly Delirium or Chilcotin.
    Delirium is burly as heck and best technical climber I've ever ridden to date. Don't make em anymore, although Fanatyko in Whistler had a medium (maybe still does).
    Chilcotin is adjustable geo, so you can slack it out for smoother jumpy stuff or a bit steeper for climby/techy slow stuff. Surgical precision handling. Runs whistler park, east coast park, east coast everything tech & does well up to 10' lip to lip with good transition. Also does great on 3-5 hour pedally rides.
    I hear good things at the park about the one. Can't say I hear much about it on east coast trail though.
    No doubt. I don't think I will join the carbon craze anytime soon, or ever, when it comes to frames. I do love my carbon Enve DH bars, but I will stick with aluminum for this next AM build.
    Stand back
    Reputation: dbabuser's Avatar
    On the more affordable side, you can probably pick up a Transition Bottlerocket for cheap. Only 5" of travel, but with an adjustable headset you can get the HA where you want it.
    A Nomad or Enduro would likely be a bit tougher than your old 575, too. I've had good luck with my '12 Enduro comp, and my neighbor has has no troubles with his Nomad C, even set up with a Boxxer for racing easier DH courses.
    Golden Bike Park
    Golden Connector Trails need your support!
    I don't have a new one, I had an old one. It was crap. They engineered their frame to be very stiff, but it was crap in every other way. Used a super-long like 4-5" bolt through the scissor linkage and rear shock that bent constantly due to it being so long (look at modern linkage bikes that use very short shock bolts for this reason). The rear suspension was crap with the curnut shock, rode harsh over most stuff and had a terrible rebound-clunk that I tried to get fixed 3x (on the last turn-around they claimed to had rebuild it, but it still felt the same). I eventually replaced it with a DHX, but the linkage didn't actually adjust the rate of the suspension, just added rigidity, so it never felt plush like on a linkage bike, or a better way to say it is that it felt like a lot less than the claimed travel, poor quality of travel. Geometry was fun, nimble, not as stable at high speed, etc. I'd never buy another bike from them though, it seems they've fixed most of these issues and transitioned from their curnut shocks to normal shocks and even linkage-controlled designs, but given how vehemently they defended those curnut shocks and their non-linkage designs 5 years ago I have a hard time trusting them. The curnut was just that bad and the suspension design of the frame sacrificed everything for lateral stiffness, even suspension performance.
    The knolly DT though...that's one burly bike with great suspension and you should be able to pick one up for a reasonable deal:
    Jan 2009
    defo agree,,, the dt is a awesome bike, never had any troubble with my dt in 4 years of owning one. it climbs well, jumps well and decends great too. even at 43lbs it was still a fun bike to climb,
    the newer delirium is a improved version, you wont be dissapointed, and you should beable to get a used one cheap.
    Jan 2009
    Quote Originally Posted by thefriar View Post
    yes they do mate.... fanatyko in whistler still have a medium raw 2011 delirium with fox dhx 5 air forsale. think it was arround 1300 can dollar. this would be a awesome bike for you.
    I want to try the Canfield in an XL, but they are sold out. Nothing until Mid-Spring 2014.
    @charging_rhinos, I found your review from this year on The One and I am sold.
    OSM
    OSM is offline
    Reputation: OSM's Avatar
    Jan 2009
    My 2011 Meta 55 has been bullet proof. more than a whole season of super D racing. No joke, more than 1 million feet of climbing. A couple real DH races. Downieville trips, jump parks, 12'+ drops, 50' far triple jumps. I did 250 hours of trails in a year on the Commencal and it is still solid. It may only be 140mm but where i mostly ride that is all that is needed.
    Bicycles D'opinion/ COMMENCAL /Principat D'Andorra
  1. saddles with strongest rails
    By PretendGentleman in forum General Discussion
    Last Post: 07-16-2013, 11:42 AM
  2. Strongest 29er rim?
    By bzo75 in forum 29er Components
    Last Post: 05-13-2013, 01:27 PM
  3. What are the strongest 9 speed chains available?
    By xufima in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-12-2013, 08:09 AM
  4. Strongest fatty rim?
    By woody_8_5 in forum Fat bikes
    Last Post: 06-15-2012, 09:07 PM
  5. Worlds Strongest Bike
    By iheartbicycles in forum Foes
    Last Post: 03-25-2012, 06:48 PM
