Sram XO RD cage replacement.- Mtbr.com
    Are the 2005 (pre-carbon cage) Sram XO RD cages compatible/ interchangeable with the newer Sram XOs?
    Furthermore, do any versions of the X9 have a replaceable cage? Compatible with XOs?
    Reputation: norbar's Avatar
    Make the cage yourself. It's easy if you get a 30x30cm piece of carbon.
    www.totalbikes.pl - Bike Camps not only in Poland
    Commit or eat sh!t
    Reputation: Cable0guy's Avatar
    Older X0's are compatible. Cages are expensive though. Probably cheaper just picking up a used one.
    Reputation: daisycutter's Avatar
    best solution buy an x9, that way it will be less painfull when you break it.
