SRAM vs Shimano- Mtbr.com
Results 1 to 26 of 26
Thread: SRAM vs Shimano
    Reputation: mr.chameleon's Avatar
    SRAM vs Shimano
    just switched over to shimano derailer and shifter and noticed a more crisp and fast difference in my shifting. i have a sram derailer and shifter also but now that i have shimano i am thinking about doing a full shimano drive train. any opinions on the brands?
    <a href="https://photobucket.com" target="_blank"><img src="https://i6.photobucket.com/albums/y241/360madness/DSCF0662.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
    Meh.
    Reputation: XSL_WiLL's Avatar
    Most people feel the opposite.
    Shimano is like a luxury car with a very smooth transmission. SRAM is like a EVO IX with a super aggressive clutch.
    Are you sure you had the SRAM drivetrain set up properly?
    Aug 2005
    Why switch to a full shimano drivetrain? As far as brands go try to stay at the LX or higher level for cranks and XT or higher for drivetrain stuff. What RD and shifter do you have from shimano and what sram RD and shifter did you have? Most "think" they have an improvement when switching to SRAM.
    Aug 2005
    Posted at the same time.
    its a possibility but i would have it tuned all the time.
    it was a strong recpmendation from a friend. plus my old sram fornt derailer broke
    Rear - Sram
    Front - Shimano
    Shifters - Sram
    Sram rear has a better pull ratio which causes the der. to shift when told to.
    Reputation: Hardtails Are Better's Avatar
    May 2005
    The difference is probably either that you went to a higher end Shimano drivetrain (I see you were using X.7), or that it's just that the Shimano is brand new, or both. I don't see any reason to jump to Shimano just because. Wheels would be the first thing I upgraded on that bike (depends a bit on hubs though), and then brakes.
    moaaar shimz
    Reputation: tacubaya's Avatar
    I have SRAM shifters and Shimano XT RD and it shifts perfectly
    yea wheels are my upgrade i wish i had the money for.brakes are soon to be avids, but only reason i tried shimano was because the sram broke.
    Meh.
    I had to mess around with my XTR all the time to keep it perfect. I've only adjusted my x9s once to compensate for cable stretch. The lower end stuff did not feel as nice, and if it had developed slop, or gunked up cables; that could explain the poor shifting.
    Slow Patrol
    Ditto on X9. Only adjusted for cable stretch and even then not because it was shifting bad. I just checked if my cable(s) had stretched. My previous Shimano was finiky and needed tweaking. So I think the SRAM 1:1 ratio is a help here.
    Also my SRAM seems to hold chain tension better. I once saw a video someone made on SRAM vs. Shimano. They actually mounted a camera on the side of the bike looking at the deraileur from the side and pedaled through some baby heads. The Shimano parallelogram and arm were flopping all over the place. On the SRAM the parallelogram was steady and only the arm flopped around some.
    moaaar shimz
    Quote Originally Posted by NormanPCN
    That is crap, Shimano and SRAM designs are different and that video just shows that Shimano has one upper pivot which moves much more than SRAM. This can compensate when you hit a branch the Shimano whill move up and probably save itself while the SRAM will get stuck and break off..
    Only real advantage from SRAM to Shimano is a bit stronger spring and 1:1 ratio. I am very happy with my XT and with a chainguide I have vey very little chain movement.
    May 2005
    Quote Originally Posted by tacubaya
    Right. All that video shows is that they're designed differently. I just blew up the XT dereilleur on one of my bikes, so I made the jump to X.9/ X.0 since I like the ergonomics of the Sram trigger a bit better than Shimanos, and I liked the idea of a stiffer return spring. The new bits should be here in a day or two, so I can't really comment on shifting performance yet.
    I love the set it and forget it feature of SRAM. My old XT would get out of tune during 1 ride. I have raced on my X9 stuff twice and practiced a few more times and I haven't had to adjust anything.
    I'm sold.
    2011 Sponsors: Rocky Mountain Racing, Golden Bike Shop, WTB
    Reputation: NAYR751's Avatar
    I guess I have to post this vid again. Click on the vid at the bottom of the page sram vs. shimano http://dhracers.com/videos.htm
    Slow Patrol
    If the deraileur position and chain tensioin are as good as is possible for a given gear combo and deraileur design when the bike is static then the closer to that state the deraileur can maintain while the bike is bouncing around the better. No?
    Reputation: rollertoaster's Avatar
    I have both, xtr on my XC bike, and x.o on my FR. The xtr is good but always needs adjustment. the X.O is way more reliable and almost never needs adjustment. The X.O also is far more tolerant to dirt and mud due to the 1:1 cable ratio. As far as durability both are very strong and have taken quite a beating.
    PULL
    Reputation: NoManerz's Avatar
    Feb 2006
    Quote Originally Posted by rollertoaster
    I agree with ya. Just replaced my xtr with a xo... could not be happier.
    Reputation: norcobryce's Avatar
    i dont get i go to one bike shop and they say sram shifts way better and it is a fact not an opinion. then another guy at the bike shop says shimano shifts way better and its a fact not an opinion. maybe they both shift different ways and it depends on what you like. but my opionion is sram.
    More Riding Less Internet
    Reputation: thom9719's Avatar
    Jan 2005
    I've used every shimano derrailur on the market and nothing compares to the SRAM. anyone who says differently did NOT have there stuff set up properly.
    Kyle,
    Meh.
    Quote Originally Posted by thom9719
    Kyle,
    Some people just can't get used to the thumb-thumb action. It took me like 20 feet to get used to it.
    Some people like the smoother shifts of Shimano.
    Some Assembly Required
    Reputation: man w/ one hand's Avatar
    Any new drive train will feel better than what you were running if it was old. Apples to oranges. SRAM is easy to set up doesn't need near as much adjustment as Shimano & is easy to get when you need it. X.0 or X.9 shifters + X.9 derailluer = sweet crisp setup.
    "Why are you willing to take so much & leave others in need...just because you can?"
    Reputation: Quarashi's Avatar
    I don't think XTR is actually equivalent to X.O. Here in the Philippines XTR costs a little less than X.9 while X.O is almost double the cost of XTR.
    About buying a bike:
    Quote Originally Posted by No MSG
    It's like finding a wife. Personality is important, but you gotta look at that face every morning.
    May 2005
    Quote Originally Posted by Quarashi
    They're not too different price wise stateside.
    Glad to Be Alive
    for DH I am sticking with the heavier spring SRams......less pounding against the frame
