sram compatability question- Mtbr.com
Results 1 to 6 of 6
    So I got $40 bonus bucks to spend over at universal cycles and because of all the play in LX rear deraileur I'm gonna spend the money on the new one. I was wondering if a Sram 7.0 will be compatible with my deore shifters.
    Thanks for the help.
    Evan
    Nope, different pull ratios exist between shimano and sram components. Is your derailleur old? I've had an LX on a much abused, poorly maintained hardtail, and it's still good as new. Just curious if I should be expecting mine to conk out. If you want to keep things cheap, just get a Deore rear der. It does the job.
    Reputation: 006_007's Avatar
    Quote Originally Posted by mtnbiker662
    Evan
    As Shibby said, not compatible. Sram makes shifters that are compatible with Shimano derailleurs, but not the other way around.
    If you are still considering the upgrade (shifters plus derailleur) I would say go for it. I switched from Shimano triggers to SRAM triggers about 6 months ago, absolutely love the 1:1 actuation ratio. Will be a long time before I go back to Shimano (esp with all their rapid rise....)
    TJ
    thanks for the help. As for your question Shibby... I've got it on my 2002 Rocky Mountain. I've ridden it for 2 seasons and the problem is fairly recent. It really got bad after a day of downhilling at Mount Snow. I had it adjusted and it works okay. Every now and then there is a little delay in shifting and I have to hold the lever a little longer than I used to but other than being a little annoying it's not really a big deal.
    So, is there actual 'play', as in, is there free movements in the pivots of the derailleur? Do you think the cage is bent a little? I've had mine for 5 years, and have had shifting problems happen 3 or 4 times, and some cleaning/fine tuning cleared up the problem. You probably thought of all this, but I thought I'd put it out there, just in case.
    yes there is actual free movement in the pivots. No cleaning will help the problem. Its just another thing that needs replacing over time.
  1. SRAM Gripshift cables....Question
    By fz4vgq in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-18-2007, 11:04 AM
  2. Shimano vs Sram another question...
    By FB296 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-28-2004, 07:33 AM
  3. Sram X.9 question....
    By msugma in forum General Discussion
    Last Post: 08-29-2004, 05:04 PM
  4. Question regarding Sachs Quartz and Sram Shifters
    By FLYBYU in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-14-2004, 08:24 PM
  5. Sram der. question
    By Erok in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-29-2004, 01:20 AM
