• 06-30-2005
    ajw8899
    Simple bike adjustments for an idiot
    Im definetly no mechanic. Can somebody tell me how i can tighten up my Hayes HFX 9's? When I grab all of the brake the lever hits the handlebar. What do I have to adjust? What do I need? It seems too trivial to take it to a shop. I know I sound like an idiot.
    Also, my grip starting spinning after my trip to Mt. Snow. Does this mean I need a new one or can it be fixed? Its the stock grips from a 2005 Gemini 900 if that helps any.
  • 06-30-2005
    DanD
    bleed your brake and buy some lock on grips.
  • 06-30-2005
    MX 887
    Before you bleed your brakes just try screwing the lever reach adjustment allen screw in. It will come out after a few days.
  • 06-30-2005
    Arkon
    problem one- screw in the allen screw so your lever adjusts out farther first. If you are still having a problem, look at bleeding the system. (i don't know what "they will come out in a few days" is in reference too)
    As far as the grips go- you can glue your grips on or buy a set of lock ons. a slipping grip does not mean the grip is bad. Lock ons are a nice cheap upgrade though.
