Sherman Slider Plus vs. Dorado- Mtbr.com
Poll: Fork you
Results 1 to 5 of 5
    New School
    Reputation: Cmac's Avatar
    Manitou tells me that they are the same internals, just different fork structure. So I guess that that means that the Dorado is an inverted Sherman for 700 dollars more. Does anyone know if this is the case, or whatever it may be. Also, how does the Sherman Plus work in rocky courses. Thanks for the input.
    ALGIO E OLIO!
    Reputation: MTBsSd's Avatar
    What are you planning on using the fork for?? The dorado is the DH race fork to go with as far as sherman va. dorado. But the slider will give you a bit more for the freeride section...
    "Better safe than scarry"
    www.3dmtb.net
    Former Noob Herder
    Reputation: zedro's Avatar
    the Dorado seems kinda pointless at that price; its also a pound heavier, probably more fragile and only has 10mm more travel.
    would look at the 888 before a dorado.
    Cynical Bystander
    Reputation: COmtbiker12's Avatar
    Quote Originally Posted by Cmac
    The Dorado seems to be wider than the Slider so that's a plus i think. Dorado's definitely a race fork. If you were set on that there's some nice ones going on ridemonkey for 5-600.
    Tony
    is making a comeback.
    Turns out that five years of not mountain biking, really makes one strive to get back to it.
    New School
    But are they the same internals? Like the 7 inch dorado vs. the 7 inch sherman. Also, I ride Northstar
    ALGIO E OLIO!
  1. Boxxer Team vs Sherman Slider Plus SPV vs Junior T?
    By yoonior in forum Downhill - Freeride
    Last Post: 04-01-2004, 10:46 AM
  2. Moving rubber bumpers on sherman slider?
    By WheelieMan in forum Shocks and Suspension
    Last Post: 03-03-2004, 08:38 AM
  3. 2003 Sherman Slider info...
    By konarider in forum Downhill - Freeride
    Last Post: 01-30-2004, 11:52 AM
  4. Need feed bk on Sherman Slider "Plus"
    By man w/ one hand in forum Shocks and Suspension
    Last Post: 01-19-2004, 09:14 PM
