Sherman Flick Plus- Mtbr.com
Results 1 to 9 of 9
    Youngbuck
    Reputation: CanadianHooligan's Avatar
    Sherman Flick Plus
    I just got the fork im gonna be putting on my p.3,a sherman flick plus. It seems like a really nice fork, and it was affordable too(i got it for around 400 canadian,ive got some hook ups). Its probably gonna be set around 6 inches,that wont make the p.3 to steep will it? And this fork isnt thru axle,is that a big deal? last just post any comments on the fork. thanks
    Sorry dont got any pics, soon ill have either pics of the fork/frame or the bike just built up.
    Honorary Member of the: 500 club
    Sep 2004
    i had that fork, waaaayyyy too plush and heavy for me, getten a pike soon
    Uhhhhh...
    Reputation: TheSherpa's Avatar
    Quote Originally Posted by Richard85
    Fayetteville, AR and N.W.A RePrEsEnT
    Blanco
    The fork is sprung way too softly for most adults. Also the firm is barely stiffer than the medium: get an x-firm spring if you need to upgrade.
    Other than that, it's been treating me very well. I think it's the perfect Moab fork unless you're so sickter gnar that you need a dual-crown.
    T.Dot Represent
    Reputation: finchy's Avatar
    i ahev the sherman flick p[lus 2005 with a thru axle and am very happy with it
    it is way to plush in my opinion though
    fiiiiiiiiiiiinchizzzzzzzzzzle
    Youngbuck
    I havent got a chance to ride on it yet so ill post when i actually get to test it out. All i can say right now is it looks nice lol.
    eminence front
    Reputation: xray's Avatar
    May 2005
    Do you guys think it would be too plush for someone who's 120lbs? I'm only 115, and maybe 120 with gear.
    Thanks.
    Sep 2004
    I think it would be fine for a 115/120lbs rider...
    I'm 185lbs - I ran the standard spring for about 15 minutes, and then swapped in the Firm one. I need to double check the sag again in a few more hours of ride time to see how things are breaking in... but when I checked when things were new, I was right around to just above the max spec for recommended sag. It was hard to get an accurate measurement because things were "sticky".
    I may give the X-Firm a try just for the heck of it...
    Blanco
    I'm about 190 and x-firm is perfect for me. If you're 120# the medium should be fine.
    Flick+ spring weights: FYI
    http://forums.mtbr.com/showthread.php?t=73763
  1. '05 Sherman Flick - Views
    By jonk in forum Shocks and Suspension
    Last Post: 04-14-2005, 10:02 PM
  2. Retrofit TPC+ Damper into 2005 Sherman Flick Plus?
    By Kracker in forum Shocks and Suspension
    Last Post: 02-03-2005, 11:38 PM
  3. TPC vs. HSCV? '04 Z1 FR qr20 vs sherman flick '04?
    By BudhaGoodha in forum Shocks and Suspension
    Last Post: 12-25-2004, 05:54 PM
  4. 04 Sherman Flick
    By AldyRider in forum Shocks and Suspension
    Last Post: 12-17-2004, 10:53 PM
  5. Gazzaloddi 3.0 into a sherman flick????
    By Executioner in forum Downhill - Freeride
    Last Post: 07-19-2004, 01:01 PM
