SERIUS brake problem (hayes hfx 9 DH/FR)- Mtbr.com
Results 1 to 19 of 19
    Reputation: Spastik Slingkee's Avatar
    yes, i know im cross threading but they didnt answer me in "brake time"
    So i was working on my bike with out the rear wheel in, and i lift up my bike and sqeeze the rear brake to stop it, THE WHEEL ISNT EVEN THERE! so i take out my pads and us a flat head screw driver to push the calipers back in and i go to the right one(upside down right) and it starts uzzing brake fluid out from around the caliper!
    What the heck do i do now! besides call my LBS and Hayes, duh (i say call because i prefer to do the work my self)
    Pinn'it Ya Fairy!
    -unknown genius
    Quote Originally Posted by Spastik Slingkee
    Sorry, sounds like you may have to re-bleed the brake line. can't fix that.
    Reputation: paintballeerXC's Avatar
    Jun 2005
    ya u are suposed to never squeze hydro breaks with out somethin inside the caliper, ur going to have to be rear bleed
    so i dont have to buy a new caliper?! i thought i might have broken a seal or something
    Pinn'it Ya Fairy!
    -unknown genius
    moaaar shimz
    Reputation: tacubaya's Avatar
    Buy new pads, rebleed.
    wat do pads have to do with anything?
    Pinn'it Ya Fairy!
    -unknown genius
    moaaar shimz
    Ur pads got splashed by oil? If they do, they are now contaminated. If not, then they are good.
    something similar happened to me but I didn't have leaking fluid. I did however have trouble with one of the calipers retracting and it had to be sent to hayes because some valve or something turned inside out. Fixed under warranty but hope you don't have that prob too.
    ok, ill just call hayes
    Pinn'it Ya Fairy!
    -unknown genius
    Now with flavor!!
    Reputation: kidwoo's Avatar
    Push the pistons back in. Rebleed the line and it should work. If not just get a piston o-ring kit, replace the rings, then rebleed. They're fine.
    STRAVA: Enabling dorks everywhere to get trails shut down........ all for the sake of a race on the internet.
    SXtreem now
    Reputation: RMXtreem's Avatar
    Save your money (in the long run) and time, get Avid's!!!
    Fort Valley = Gnarl Fest
    Reputation: Jekyll_Jockey's Avatar
    Quote Originally Posted by tacubaya
    Its true unless you soak your pads in denatured alcohol.
    Glad to Be Alive
    basically the piston came out too far........push it back in (all it is is a round cylinder with an "O" ring on it - nothing fancy)......then re-bleed....everything will be fine
    Jun 2005
    Ive heard its actually good to squeeze the brakes while there is no disc in it.
    I just wanna go fast!
    Reputation: bdamschen's Avatar
    uh... maybe because it's good to bleed your brakes every now and then? Haven't heard that one before
    I like air!
    Reputation: milhouse's Avatar
    I think the real problem is you got SERIUS instead of XM. Switch and that shoud fix your prob
    Meh.
    Reputation: XSL_WiLL's Avatar
    Come on guys, I'm being super serial! Why doesn't anybody take me serial? The man-bear-pig is out there!
    Denatured alcohol will not fix contaminated pads. You can clean and burn off some of the DOT fluid, but you will never get all of it. Braking performance WILL still be affected.
    Sounds like you pushed the pistons out too far. Inspect the seals for damage, or excessive wear. Replace if neccesary. Push the pistons back in (NOT WITH A SCREWDRIVER). Do not push the pistons in by the center post either. Use a box-wrench and work it back in. There's a good chance you'll need to rebleed.
    The 9s are pretty poor. Anybody want to buy a pair?
    Excelsior!
    sorry, i guess i stated it wrong, i pushed the right cylinder in, THEN it started leaking. NO LIQUIDS GOT ON THE PADS, they are fine!
    2 day i finished replacing my chain and cassette and i decided to see wat would happen if i tried to put the pads back in and went along like nothing happened. well, it worked, the cylinder dont leak any more but i lost some fluid so i just need to re-bleed, i guess u guys were right.
    Pinn'it Ya Fairy!
    -unknown genius
    Meh.
    Your description was vague at best.
