seatpost problems- Mtbr.com
Results 1 to 5 of 5
    Ghost ride the whip!
    Apr 2005
    seatpost problems
    I was recently given a "da bomb" sputnik for free. The problem is, it takes a 31.4 seatpost.
    The only one i found in the U.S. was a kalloy. No Thanks.
    I can get the "da bomb" seatpost in 31.4 but i have to order it from a shop in israel. Which is fine, im not really in any rush.
    My other solution is to use a shim. But the only shims for a 31.4 use a 27.2 seatpost.
    Should i be uneasy with using the 27.2 with the shim?
    Shoud I buy the one made by da bomb?
    Do you have one?
    Oh, and whats a good chainguide to use if your bike doesn't have iscg mounts and you are running a single up front with a 9sp in back?
    Reputation: mb3designs's Avatar
    If you can find one, Syncros used to make a post in 31.4 called the Hardcore. Might be hard to find since they don't manufacture them anymore. Sorry I could not be of more help to you, good luck.
    Apr 2005
    I looked all over for the synchros. I just think the kalloy one sucks and if I crash too crazy i don't want the shim+seatpost combo to mess up the frame. Looks like im oerdering from overseas...
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    i've been using a shim for a while now and have never had any issues with it, and i'm sure my DJ bike crashes way more than you do......
    Apr 2005
    Quote Originally Posted by .WestCoastHucker.
    Sweet, thats what I wanted to hear!
