Saint Rear Der Question.- Mtbr.com
Results 1 to 2 of 2
    Loves His Sunday
    Reputation: mxrider489's Avatar
    What are the differences between shortcage horizontal, shortcage vertical, mid cage vertical, midcage horizontal, long cage vertical, long cage horizontal. Could some on explain to me what this means? Advantages/Disadvantages? Which do I want on my 04 Stinky for heavy freeriding and some downhill?
    Reputation: RobsterCraw's Avatar
    The lenght of the cage is up for you to decide. If you have 3 chainrings then you need the long cage. If you run two then the middle or short should work ok. Running one chainrings means you only need the short cage. Generally, if your doing DH or FR you want to keep to the shorter cages if you can. The horizontal and vertical thing is talking about your dropouts for your rear axel. Some are horizontal, most are vertical.
    Im pretty sure thats right but then again I'm no expert
  1. X9 rear der question
    By ozlongboarder in forum Australia, New Zealand
    Last Post: 01-16-2005, 01:13 AM
  2. Compatibility of Saint rear der & Crossmax XL
    By yikerns in forum Riding Passion
    Last Post: 08-02-2004, 09:37 PM
  3. x.9 rear der. upper pulley question
    By ToddM in forum SRAM
    Last Post: 05-04-2004, 05:41 PM
  4. Replies: 7
    Last Post: 03-09-2004, 07:03 AM
  5. Shimano M960 rear der. question
    By mtb_biker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-29-2004, 03:42 PM
