Rock Shox Pike On My Chase!?- Mtbr.com
Results 1 to 8 of 8
    Soul Cycles
    Jan 2005
    Should i put a Pike on my cannondale chase, im looking for a street/urban/freeride fork. do you think this is a good fork for this. what fork do you thihnk i should get forr my chase?
    Reputation: OneBlueJoker's Avatar
    Quote Originally Posted by sreiman
    i think its a great fork for that type of riding! its supoppsed to be a sweet fork and you should love it!
    I have a pike and they are killer forks. I'd say, go get the pike. I have a sherman firefly and the pike is a better fork. It feals stronger and is both, more plush and stiff than the sherman. And you can run the pike all the way down to 95mm if you want a steep head angle. Or 140mm when you feal like hitten a stair gap.
    WHAT HAS SCIENCE DONE!?!
    Reputation: Skygrounder's Avatar
    Does the spring rate change when you adjust travel on a Pike?
    --Tod
    "I don't pretend to understand Brannigan's law; I merely enforce it."
    Generation X freerider
    Reputation: cdog117's Avatar
    no the spring rate doesnt change
    Te mortuo heres tibi sim?
    Quote Originally Posted by cdog117
    uh, yes it does. straight from the manual in my hands......
    and downloadable as a pdf on the rock shox site......
    http://www.sram.com/_media/pdf/rocks...ke_English.pdf
    gnar, brah
    Reputation: Andrewpalooza's Avatar
    Dec 2004
    Quote Originally Posted by scrublover
    I'll second that. Although I believe it may have been advertised as no change in spring rate.
    If you are a light guy you might see a difference in the spring getting stiffer. But if you are a big guy like myself, you will hardly tell it. Any spring you tork down will get stiffer as you put pressure on it. Uturn or not.
  1. 05' Rock Shox Pike Team vs. 05' Fox Vanilla RLC
    By jgusta in forum Shocks and Suspension
    Last Post: 11-19-2004, 02:38 PM
  2. Rock Shox Pike Race
    By Dirtman in forum Shocks and Suspension
    Last Post: 11-18-2004, 09:57 AM
  3. Rock Shox Pike
    By WeylessXPRider in forum Shocks and Suspension
    Last Post: 09-21-2004, 09:46 AM
  4. Rock Shox Pike & Uzzi SLX
    By BobKreyole in forum Shocks and Suspension
    Last Post: 09-09-2004, 07:18 PM
  5. Rock Shox Pike & Uzzi SLX
    By BobKreyole in forum Intense
    Last Post: 09-09-2004, 09:45 AM
