Road derailleurs ?- Mtbr.com
Results 1 to 12 of 12
    Authority is dead!
    Reputation: Lucky13's Avatar
    Road derailleurs ?
    I am hearing some use road derailleurs on their downhill and freeride rigs. What are the limits and specifics? Say I want something really small (very rocky trails is all I ride pretty much) that would work on my '03 BigHit with standard 9 speed set up. XT works for me, but I keep clipping stuff with it.
    For the love of Oi
    Rent a house at Attitash
    I run a shimano 105 short cage....works great with a 11-30t 8-speed cassette and single front. I like it because it's cheap, light and has excellent ground clearance because the cage is so short.
    Authority is dead!
    P.S. I got 2x9. 11-34 + 22&32.
    For the love of Oi
    Reputation: thebikedoctor33's Avatar
    i dont think your gunna find a road deralluer to go up to 34 teeth. you can try. most ppl who run road derailluers also run road cassettes
    Authority is dead!
    What's the highest gear on road cassettes?
    For the love of Oi
    shimano makes up to 27. sram 26. and campy makes 29, but its ten spd. you can still run it using 9 i think. but the campy is pretty expensive. over $100
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    Don't Shimano and SRAM still make a mid-cage MTB derailleur? I'm too lazy to go look on their sites, but I thought both companies made a unit like this. It's not as short as a road derailleur, but it's shorter than an MTB unit. I have an XTR mid-cage on my road bike.
    Authority is dead!
    i trash that shitmano "short cage" stuff.
    For the love of Oi
    yes, they do.
    TNC
    TNC is offline
    noMAD man
    Maybe you're a candidate...
    Quote Originally Posted by Lucky13
    for a Rohloff. I know, I know...they're godawful expensive and a little heavy.
    Meh.
    Reputation: XSL_WiLL's Avatar
    If you're running 2-ring setup, get the midcage.
    Doesn't Campy need to be used with Campy shifters? And Campy cassettes? And Campy hubs?
    i'm not sure. you can run them with shimano shifter but it wont be perfectly clean. as for hubs, i'm almost positive you can run them on regular cassette hubs
