rhino lytes- Mtbr.com
Results 1 to 8 of 8
Thread: rhino lytes
    Mar 2005
    rhino lytes
    what do ya think of sun rims rino lytes any good?
    Apr 2005
    Quote Originally Posted by hughairboy188c
    I have used them for the last 2 years. Keep then true and they are strong. I have done many 6 foot drops onto Flat (Concrete) and haven't destroyed the rims yet. Get a strong hub to back them up. I used XT Disc hubs because that is what I had at the time. I'm constantly tightening the cones and rarely truing the wheels.
    My next set of wheels (when I get tried of screwing with the hub (REAR)) will have DT Swiss hubs Either the Onyx or FR's Depends on the cash flow.
    Mar 2005
    ok thanks i hit alotmost that big on my hardtail i got rinos ont the front and alexrims dh20 on the back
    MTBR Mafia
    Reputation: cdub's Avatar
    Feb 2005
    gone pretty big on mine and they seen real strong, light too. i also have XT hubs, they seem good at the moment
    gnar, brah
    Reputation: Andrewpalooza's Avatar
    Dec 2004
    Awesome rims, they'll survive some rough stuff. Not the strongest for DH/FR, but they aren't really meant for that either. More of an aggressive-XC rim that is super strong. They seem to stress the hub for me too...constantly tightening the cones and so forth...
    Trestle Bike Park
    probably be the best to bite the bullet and save up for a rim designed for dh/fr
    Meh.
    Reputation: XSL_WiLL's Avatar
    If you have them handbuilt by a competent wheelbuilder, any rim/hub combo can be built very strong. When I was short on cash I had my Alex DM-18 rims laced to Joytech hubs I had around with DT Swiss 2.0 spokes (double butted). The wheelbuilder told me that the spokes would allow the rims to flex a bit under hard impacts, so it would hold up better in the long run. I've used them for light freeride and dirtjumping and they're holding up fine. Since then, I've learned to build my own wheels, seeing as how I'm one of the mechanics at the local shop now... I used to have Rhynolite XLs on my Haro Escape, they were great rims, nice strength to weight ratio. They're more of a aggro xc rim, but they build up very strong.
    Prof. of Doomology
    Reputation: drdoom's Avatar
    Jan 2005
    they are a pretty damn good deal, just make sure you get the ones with the xt or better hubs, i regret getting the cheaper ones simply because the lx hubs or whatever they are blow. another thing is that they don't come tensioned very tight so before every ride you should definitly check the tension. the rims themselves are pretty strong, i had a mavic crossland rim that i was running kinda low psi on cause of a small leak and destroyed it, running the same psi on the rhyno lites and they're holden up just fine. they are kinda heavy, fyi
    I ain't got time to bleed - Jesse Ventura, Predator
    My name......Inigo Montoya....you have killed my father......prepare to die! - Mandy Patinkin, The Princess Bride
  1. Howzabout some derailleur porn?
    By terminaut in forum Vintage, Retro, Classic
    Last Post: 04-01-2011, 03:37 AM
  2. Sun Rhyno Lite XL or Sun Single Tracks?
    By cement54 in forum Wheels and Tires
    Last Post: 02-07-2005, 02:57 PM
  3. rhino rockstrong cranks?
    By dompedro3 in forum Singlespeed
    Last Post: 10-14-2004, 01:15 PM
  4. Questions about Rhino Liners...
    By InnocentCriminal in forum General Discussion
    Last Post: 06-22-2004, 02:52 AM
  5. KMan jm rhino cranks?
    Last Post: 04-28-2004, 12:05 PM
