removing a 20mm hub- Mtbr.com
Results 1 to 10 of 10
    removing a 20mm hub
    hi, i am an idiot. i am new to this 20mm hub deal. how do i get it off my fork? i undid the bolt on the one fork leg. now do i hammer it out or get a big hex wrench and unscrew the one side of the axl. i didn't have the right size hex to use last night so i couldnt test the hex "theory". and the hammer "theory" was scaring me as i didnt want to break my hub.
    Glad to Be Alive
    What fork??? What year of fork???
    2002 Monster T. Hope hub
    Quote Originally Posted by SHIVER ME TIMBERS
    Reputation: mike67's Avatar
    Quote Originally Posted by ini88
    Loosen pinch bolts on both drop outs, use hex wrench to loosen axle, then slide it out. If I remember right, the axle has reverse threads.
    Reputation: frank n. beans's Avatar
    When in doubt, ALWAYS use a hammer. That definitely sounds like the best method to uninstall a wheel.
    so i need the hex wrench to unscrew it the opposite way. then it will come out. i noticed only a hex side on one of the sides. not both.
    Quote Originally Posted by mike67
    There may only be one pinch bolt, then use a hex key to loosen the axle, and it should push right out. I *think they are reverse threads* the axle shouldn't be very tight, so ease into it.
    haha, i had the hammer in one hand and the fork in the other ready to hammer that **** out of the hub. then i though. "what the hell am i doing?" everything on a bike uses an allen wrench. thats when i knew something was wrong and needed to ask a question.
    Quote Originally Posted by frank n. beans
    Reputation: skywaybuzz's Avatar
    8mm hex wrench.
    thank you all. i am not longer an idiot. more of a dumbass now.
    Quote Originally Posted by skywaybuzz
    8mm hex wrench.
  1. Need 20mm hub
    By SSINGA in forum Wheels and Tires
    Last Post: 10-25-2004, 08:10 PM
  2. Saint 20mm front hub & disc ?
    By TNC in forum Downhill - Freeride
    Last Post: 09-24-2004, 11:13 AM
  3. QR20 / RockShox 20mm Tullio hub compatibility?
    By FM in forum Shocks and Suspension
    Last Post: 06-06-2004, 10:08 PM
  4. Z150 info? And a good 20mm hub
    By UnitedWeRide in forum Downhill - Freeride
    Last Post: 03-17-2004, 08:36 AM
  5. best price for 20mm front hub
    By David in forum Where are the Best Deals?
    Last Post: 02-25-2004, 07:39 AM
