Reducing travel on Marzocchi- Mtbr.com
Results 1 to 37 of 37
    Authority is dead!
    Reputation: Lucky13's Avatar
    I got '99 Z.3 with 3"of travel. I want to make it down to 2". Is that the matter of cutting main spring and adding a spacer instead? Any how to's available?
    For the love of Oi
    Rent a house at Attitash
    i should be working
    Reputation: rpl3000's Avatar
    this is a shot in the dark, but thats how travel adjustment is done with the dirtjumper forks. is the 99 z-1 open bath or cartridge?
    maybe you can over fill it w/ oil so it hydro-locks before reaching 3" travel.
    have you looked at the stance static 80mm? seems like a good match for a park bike.
    Authority is dead!
    Z.3, not Z.1
    Seals will pop out
    No manipoop **** needed. Already got Marzocchi.
    For the love of Oi
    Former Noob Herder
    Reputation: zedro's Avatar
    Quote Originally Posted by Lucky13
    Z.3, not Z.1
    Seals will pop out
    yup, the spring thing will work. Remember, cutting springs will make them stiffer. Add the cut spring section or a spacer to the negative spring stack.
    Quote Originally Posted by Gunslingger
    no doubt you must have majored in english or something rad!!!
    Authority is dead!
    Quote Originally Posted by zedro
    You mean cut a piece and move it down to negative spring? Spacer or the piece of spring?
    Yeah, stiffer will be good.
    For the love of Oi
    Former Noob Herder
    you can use a spacer or the piece of cut spring. Basically whatever you remove from the postive springs, you have to add to the negative.
    Authority is dead!
    Great, thanks much Zedro!
    For the love of Oi
    customized
    Sep 2003
    Just wondering, how come you need only two inches of travel?
    You may run into problems with the cut springs biting into something inside the fork. Cutting the spring will also cause it to become stronger. The best thing to do is make some spacers out of PVC and put them with the negative springs that are already in there. I would then force the caps down and tighten them up. In effect you will have more preload on the springs. Not much different then having the stronger modified springs, but at least you won't be possibly damaging your fork from sharp springs and it will be only a couple bucks to do. I would make the spacers about 20mm. Not an inch but it will do the trick.
    Otherwise if you cut the spring you should take a torch and bend a new perch on the 4 springs. I would then grind down the perch to make it flat.
    Two methods, same outcome.
    Louis
    Former Noob Herder
    Quote Originally Posted by Severum
    i disagree. Although i dont like the idea of cutting springs, this would be more ideal than preloading the springs since the fork will handle like total crap yet may still bottom-out.
    For example, for a 40#/in spring, if you preload it one inch, due to the travel decrease, you would get probably no sag at all and the fork would feel really harsh; ie. 40pounds of force are going to go right into your wrists before the fork starts to absorb the impact (on a landing say). Now by cutting a 7" long spring to 6", you'll get a 46.6#/in (top of my head calc.) spring with zero preload (no wrist shattering), and it being stiffer will allow for more bottom out resistance with the lower travel.
    You can try it, nothing to lose really.
    and just to note, keep the cut side of the spring pointing upward into the metal washer, not the plastic pumping rod head. And year, try and flatten it out as much as possible.
    Another alternative is air prings.
    customized
    Sep 2003
    I'm doing the same mod to a Atom 80. I am getting extra top out springs and cutting the main springs. I am gonna spend the time to mod the springs accordingly.
    Your preload idea makes sense to me.
    Former Noob Herder
    also you can go to your LBS and see if they have any old short springs (like from old RSs) in the defunct bin.
    Your best bet would be just to put an extra top out spring in the bottom of the fork... It would max the preload and stiffen things up a bit....
    Brian
    Former Noob Herder
    Quote Originally Posted by Brian Peterson
    Brian
    arrrrgg...any comment on what i said above?
    I try to avoid anything that involves cutting springs....
    Brian
    Former Noob Herder
    Brian
    well, not much use in making the fork feel like crap either...
    but if it were me, i'd probably switch to air.
    It's not really going to feel any worse that if he had the preload cranked up all the way.... Now, if you tried to go any more than the one top out, yes, it would drastically effect the ride of the fork. Not to mention getting the fork back together would be a feat in itself...
    The air option would probably be a better way... Especially if he tried to go any lower with the travel...
    Brian
    Former Noob Herder
    Brian
    well he wants an inch, which is alot of preload. Also you'd need more than an inch of spacer/negative spring to actually get that inch since the springs would be pulling so much.
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    I modded my Z1CR down to 3" by clipping the springs and then addng pvc spacers to the negative stack......
    Authority is dead!
    Quote Originally Posted by .WestCoastHucker.
    You mean that you put some kind of a bracket to hold a few coils together after you've compresssed them? Could you explain a little more?
    For the love of Oi
    customized
    Sep 2003
    If I had to guess he is modding the fork for the same reason I am. I need a stiff but short travel shock for a trials/urban build. I'd go rigid but it tough on the wrists. Just using to take the edge off.
    I have some 70mm extra heavy springs coming from Marzocchi. I have to cut one spring because I am running a 2002 HSCV cart with the 2000 HSCV cart. The 2002 body is 20mm longer so it pushes that side spring up 20mm. I am going to cut that spring down to make it work. From my calculations I should still have a good 60mm of spring travel on that short spring without making it bind up on full compression.
    Authority is dead!
    "If I had to guess he is modding the fork for the same reason I am. I need a stiff but short travel shock for a trials/urban build. I'd go rigid but it tough on the wrists. Just using to take the edge off."
    Precisely. Have the same issue: just want it to be shorter in travel and a little stiffer.
    For the love of Oi
    customized
    Sep 2003
    Remove the top caps.
    Remove the foot nuts at the bottom of the fork.
    Drain the oil.
    Remove the springs.
    Remove the carts.
    There will be small springs in the bottom of stanctions.
    If you put about a 20mm length of PVC on top of each of those springs, and you reassemble, then you will lower the ride about one inch. This is essentially the same thing Ryan Leech did on his Norco trials rig. He used the stock length springs just in the extra heavy variety with extra 20mm top out springs. It will be a little work getting the top out caps back on.
    I would just ride this around a bit and see if you like it. My guess is that it will not be stiff enough. If it isn't quite right and you figure preload is the problem, then you can either get 70mm springs for $40 a pop or cut the ones you have down.
    Louis
    customized
    Sep 2003
    As a side note.
    When I had no top out springs installed I had 108mm of stanction tube exposed.
    With 1 20mm top out spring per side, I had 86mm and with 2 20mm tops out springs per side, I had 70mm of stanction exposed.
    Not that running without any top out springs is smart, just showing the difference in maximum available travel. (Yeah, it'll prolly be 5mm less actually then measured on those old Zoke forks.)
    Authority is dead!
    Yeah, thanks. I took it apart and going to strip its paint to kustomize it a bit and shorten/stiffen the travel a bit. So 20mm specer will take an inch out of the game?
    For the love of Oi
    customized
    Sep 2003
    Yeah, 20mm is less than an inch but the preloaded main springs will load the top outs down. So 20mm should do the trick. Ideally if you like the feel you should buy a pair of 20mm top out springs for it. They will run you $5 each from your shop. That way the preloaded springs don't bottom out your top outs. Not that it matters as the top outs are there for the return to full extension, but it is never wise to full compress a spring.
    Louis
    Authority is dead!
    "Ideally if you like the feel you should buy a pair of 20mm top out springs for it. They will run you $5 each from your shop" <---- and? Where do they go?
    For the love of Oi
    customized
    Sep 2003
    In place of the PVC spacers when you find out how you like it. If your not too worried about the compressed top outs, then just leave the spacers in.
    I still think you'll find your interested in heavier springs later. Front wheel moves would be a lot easier with a stiffer fork.
    Louis
    Authority is dead!
    That's what I'm looking for. I had a stiff dirt jumper 2 ('02) b4 with like 2.5" and it was sick, but flexy. Now I got this Z.3 with 20mm axel; should be sick! Thanks for your help Loius.
    For the love of Oi
    Pro Crastinator
    i made my spacers 40mm long because i cut 40mm off my 110mm top springs, then put that spacer at the bottom of the negative spring stack assembly....
    Glad to Be Alive
    WCH banned from Fontana
    Pro Crastinator
    hater....
    Glad to Be Alive
    u don't call me anymore...3 times this weekend is not enough....I wonder about you. Did you have fun dis weekend...any weekday rides???
    Authority is dead!
    Thank ya all.
    For the love of Oi
    Authority is dead!
    Sorry to bring the thread back, but how about cutting those plastic spacers on top of main springs by the length of the spacer added so I won't have to force top caps back on? I decided just to add spacers without cutting the spring.
    For the love of Oi
    customized
    Sep 2003
    Oh yeah, your model fork has the spacers on top. That will work great.
    Louis
    Authority is dead!
    so cutting them to the length of spacers is the way to go?
    For the love of Oi
    customized
    Sep 2003
    Yeah, cut 20mm off the spacers, stuff the 20mm pieces with the top out springs and the remainder goes on top of the main springs.
    Louis
  1. Whistler and 2005 Marzocchi Line
    By Photo-John in forum Downhill - Freeride
    Last Post: 08-10-2004, 03:46 PM
  2. Changing travel in a Marzocchi MX comp w/ETA
    By Kelvin in forum Shocks and Suspension
    Last Post: 06-16-2004, 09:39 PM
  3. Reducing travel on Sherman?
    By dooner in forum Shocks and Suspension
    Last Post: 04-05-2004, 09:40 AM
  4. Marzocchi MX Comp full travel? (OEM on 03 enduro)
    By phil. in forum Shocks and Suspension
    Last Post: 03-30-2004, 12:58 PM
