Rebuilding an old DH Rig- Mtbr.com
Results 1 to 3 of 3
    Jan 2019
    Hello everyone,
    I used to ride and race Downhill when I was in my teens. At the time time I would go building a top quality bike on a KHS Dominatrix Frame.
    Boxer front fork might be a year 99 or 2000. Avalanche Rear strut. and top of the line accessories at the time. Hayes disc Brakes ect. etc.
    Im 33 now and the the bike has been sitting for 18 or so years and I'm Interested in riding again. Can I have the fork serviced or do it myself? are the breaks able to be re built with new seals? I'm sure avalanche can re build the shock for me, but I'm not sure where else to start.
    Any advice is appreciated.
    Gary
    Sent from my SM-G920V using Tapatalk
    Big M, Little organ.
    Thats cool to bring an old bike back into service! I would do a basic service of everything yourself first. Fluid and fork seals on the fork, new hydraulic fluid in the brakes, new shift cables, new pads, check and lube every bearing and replace as necessary. Assuming this wasn't left outside and rusted many parts are probably fine.
    You can find parts for old hayes disk brakes and boxxer forks online. Bearings are all standard sizes. Rear shocks are not a DIY thing for most people so if that has issues its time to find a shop. Shops around here are ~$150-200 for a rebuild.
    Here are the part numbers for 2000 boxxers:
    http://www.pigseye.com/bikes/Jenny/R...spareparts.pdf
    You probably have G1 HFX brakes, which are easy to rebuild. Piston seal at the caliper is probably shot but caliper rebuild kits are $20 and easily found online. Universalcycles has them for sure. Definitely change the fluid.
    Hope you get your bike back on the trail. I'd be pretty stoked to see one out there.
    Jan 2019
    That is all great info and gets me on the right track. Thanks so much.
    The frame is a turd unfortunately. it was very poorly designed. It suffers from terrible peddle bob and has some breakage issues.
    I found some frames from the same era on eBay for only a few hundred bucks. Id love to move everything over to an old Intense M1 or a Santa Cruz Super 8 If I do get riding again.
  1. Rebuilding old Trek..Square Taper BB?
    By NJTransplant in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-17-2013, 01:54 PM
  2. Rebuilding an old friend
    By Wade410 in forum Vintage, Retro, Classic
    Last Post: 05-18-2013, 05:16 PM
  3. Rebuilding Old Coil Shock
    By blown240 in forum Shocks and Suspension
    Last Post: 02-17-2013, 05:58 AM
  4. Rebuilding An Old Schwinn
    By Kona0197 in forum Vintage, Retro, Classic
    Last Post: 12-09-2012, 09:52 PM
  5. old (04ish) Float R AVA weeping.. worth rebuilding?
    By ColinL in forum Shocks and Suspension
    Last Post: 10-24-2012, 02:02 PM
Members who have read this thread: 7
