rear hub on judge 2- Mtbr.com
Results 1 to 6 of 6
    Cannondale17
    rear hub on judge 2
    hey i just got a 06 judge 2 frame and have a quick question on the rear axle, it says that it needs a 150mm rear thru 12 axle but ive heard of people putting 135mm and spacing it is this possible or do i have to go with the 150mm?
    thanks
    Meh.
    Reputation: XSL_WiLL's Avatar
    Not possible to run a 135mm hub in a 150mm frame.
    Cannondale17
    alright i thought so but would have been easier to make the swap wit a 135mm... oh well good enough time to go out and find me a 150mm rear wheel.....
    Reputation: xKREDx's Avatar
    Yeah you need to use a 150mm hub you cant use a 135mm hub.
    Quote Originally Posted by shredder111
    Can I paint your rockring, silly bun salad?
    Glad to Be Alive
    yeah you need a new hub.....the 150mm hub was designed to give you a better chain line
    Meh.
    150mm hub also builds a stronger wheel.
