Rear derailler problems- Mtbr.com
Results 1 to 7 of 7
    Feb 2005
    I don't know all the proper terminoligy so please bear with me here.
    I noticed the other day that the bottom of the derailler (the two pulleys where the chain goes through) is coming VERY close to my spokes and is actually knicking them sometimes.
    Does anyone know how this is solved? My gears still work fine, but im worrried that it is going to get worse and eventually get snagged in the spokes at speed and causing major problems.
    Anyways, do I need a new derailler? Or is there a quick fix or adjustment that will do the trick?
    Thanks for your time
    Dustin
    Reputation: flatulentfox's Avatar
    facing the drive side of the bike, grab hold of the bottom of the derailleur, and bend it towards you
    Reputation: cornholio's Avatar
    bent derailer hanger? go to a bike shop and watch how they fix it, then next time you can fix it yourself.
    if it is bent, the safest thing would be to replace the derailer hanger. or you can try to bend it back yourself. don't yank on the derailer cage, you might f- it up even worse.
    here, read this....
    http://www.sheldonbrown.com/derailer-adjustment.html
    try typing "rear derailler" into google. here's another one.
    http://www.bikewebsite.com/derailler_adjustment.htm
    actually it seems the correct spelling is "derailleur".
    you can stick an allen wrench in that hole in the derailleur next to where it mounts to the hanger. then use that for leverage to straighten the hanger. do that at your own risk. i saw a guy at my lbs do that when i took my bike in once. it helps to see somebody else do it first. just yanking willy nilly on your derailleur can do more harm than good.
    or like i said, if the hanger is bent, just replace the hanger. it's a good idea to have 1 or 2 spares handy at all times. that's assuming your frame uses a replaceable hanger, most of them do, but not all.
    Meh.
    Reputation: XSL_WiLL's Avatar
    There's actually a tool to straighten derailleur hangers. This tool can fix bent and twisted hangers. Aluminum hangers shouldn't be straightened too often. I always keep a few spare hangers around.
    If it's still shifting well, I would bet it isn't a bent hanger, I would tighten you low limit screw. It'll have a little "L" next to it, screw that in as far as you possibly can while the derailleur is still able to shift to your lowest (biggest) cog.
    Feb 2005
    ok thanks for the replies guys, after work tonight I will see what I can do
  1. What next with this Avid rear brake
    By Skettio in forum Brake Time
    Last Post: 07-27-2005, 02:38 PM
  2. Matching front and rear travel
    By Call_me_Clyde in forum Shocks and Suspension
    Last Post: 02-24-2005, 11:00 PM
  3. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  4. @#$%^&* Shimano bottom bracket mounted derailler
    By old_dude in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-02-2004, 10:04 AM
  5. Research help
    By mg5904 in forum Bike and Frame discussion
    Last Post: 04-13-2004, 06:32 PM
