Rear brake squeak- Mtbr.com
Results 1 to 22 of 22
    pro
    pro is offline
    Oct 2007
    Rear brake squeak
    It is very loud, and not consistent. I would say the pads are to tight on the rotor. How do I "move them away"? Hayes hydraulics. Thanks!
    BrassBalled DropbarNinja
    Reputation: mrpercussive's Avatar
    try centering the caliper... loosen the bolts on the caliper, spin the wheel and hold the brake lever. Tighten the bolts a little bit on each side alternating each time until it is tight. That way it stops the bolts from moving the caliper.
    If that didnt do the trick, could it be that the pistons are too close? Maybe the lever might have been pulled when the rotor wasnt in there. Take the wheel off and use a flat head screwdriver and stick it in between the pads. Nudge the pistons back and forth and that'll push the pistons back. After you're done with that, recenter the caliper again.
    Let us know if that helped...
    pro
    pro is offline
    Oct 2007
    Thanks! The wheel was never off (well...recently) so I'll try try first method.
    pro
    pro is offline
    Oct 2007
    No dice. Im guessing its cable tension.
    its not cable tension, theres no cables in hydraulic brakes
    push the pistons back...
    pro
    pro is offline
    Oct 2007
    Aww ****. I did something, and now all the fluid is out of the brakes. **** me!
    ...idios...
    Reputation: SteveUK's Avatar
    The loosen-brake-tighten method is useless. To align the caliper you should remove the pads and, well, align the caliper to the rotor.
    "Aww ****. I did something, and now all the fluid is out of the brakes. **** me!"
    What did you do?
    Diogenes
    Loose Spokes...
    You might want to go a little further out to find the reason... loose spokes can rub against each other while brakes are being applied and cause what sounds like brake squeaking. I had a similar problem with a new wheelset and just tightening the spokes up (make sure that you keep your wheel true) solved the problem.
    For reference: http://www.mtbr.com/discbrakesfaqcrx.aspx
    Brian
    pro
    pro is offline
    Oct 2007
    Quote Originally Posted by mrpercussive
    How would I do this? There is no pressure at all in the brakes. All the fluid came out. Im pretty clueless about brakes as you can see haha.
    Quote Originally Posted by pro
    where's the fluid coming out from?
    pro
    pro is offline
    Oct 2007
    Well, I loosened the 2 screws at the top of the caliper, and when I squeezed the brake, it just kinda came out of the top. I tightened it back up, and though nothing of it. I did a small drop (3 ft) to flat, and then I lost all pressure. I also noticed fluid on my wheel and tire.
    what brakes are those? and which bolts did you loosen????
    pro
    pro is offline
    Oct 2007
    Hayes. Not exactly sure which model though..
    These
    ...idios...
    And is it those two black bolts which you removed?
    Diogenes
    pro
    pro is offline
    Oct 2007
    Yeah. I didn't remove em, I just backed em out some.
    ...idios...
    The caliper is made of two halves; you've loosened the bolts that hold them together. It's fixable, but you're likely to need new pads and the system will require bleeding. If you're not confident that you can bleed the brake yourself, it may be wise to take the job to a local shop.
    You should clean all the DOT fluid from wherever it's spilled with plenty of soapy water. The brake rotor should be cleaned with Isopropyl Alcohol, although a good scrub with soapy water and plenty of fresh water to rinse will also do.
    Diogenes
    pro
    pro is offline
    Oct 2007
    Alright, Thanks.
    you loosened the wrong bolts...
    And what SteveUK said...
    pro
    pro is offline
    Oct 2007
    Im bringing it to a shop around here that specializes in DH/FR stuff. Getting the pads replaced, and new oil. I'll keep you updated.
    Glad to Be Alive
    if you don't know what ur doing.......stop and ask somebody
    it is better to ask a dumb question then explain a stupid mistake
    What this thread needs is some silent movie background music. Classic!
    What SMT said. No one said anything about screws.
