Quicky: Best Way to put on Grips- Mtbr.com
Results 1 to 18 of 18
    Reputation: edray's Avatar
    I hate putting on new grips, I just took off my existing ones, and im trying to put on the ne ones. They obviously arent Lock-On's...Whats the best way to slide them on?
    Erik
    Meh.
    Reputation: XSL_WiLL's Avatar
    Spray hairspray on the inside. It works as a lube and then it'll dry and act as a glue to keep them in place.
    I used butter for mine. May not sound "normal", but it dries and has a strong grip. They don't slide at all.
    JMH
    JMH is offline
    Sugary Exoskeleton
    Reputation: JMH's Avatar
    Feb 2005
    Two Methods
    The best:
    Dry, with an air compressor. If it has a nozzle, you can blow under the grips and slide them right on. Takes 3 seconds and they don't slip.
    Second best: Spray adhesive. Makes a mess but holds really well and dries faster and stickier than hairspray.
    JMH
    Quote Originally Posted by mondaycurse
    buy lock-ons
    not trying to sound like a smart @$$ but ithey are alot nicer.they dont slip and when they wear down they are easy to change,or if you need to switch something out on you bars.and for 15-20$ they're not a big investment.
    so this is how you add a signature!!
    wishiwereridingmybike
    Reputation: #1 Hucker's Avatar
    rubbing alcohol does the trick for me but lock-ons would be better
    Takw/agranofsalt
    Jan 2005
    Quote Originally Posted by #1 Hucker
    What he said
    Reputation: Amazing Larry104's Avatar
    Aug 2005
    use an air compressor if you have access
    IS THIS SOMETHING YOU CAN SHARE WITH THE REST OF US AMAZING LARRY ?!?!?!
    aircooled VW FTW
    dirt rules
    Reputation: sittingduck's Avatar
    Apr 2005
    Air is the bomb
    Glad to Be Alive
    aircompressor........a blast of air guides them off and on easy
    another air believer here. Lockons if you can
    Reputation: ANdRewLIu6294's Avatar
    or, if you dont have any of these, water'll do fine too. wet the bars and the inside, then get the grip as far as you can on by twisting, then slap the end of the grip. it goes all the way on
    rollin
    Reputation: sriracha's Avatar
    aquanet for that all day hold. ask your grandma.
    rockin the mid-west
    Reputation: madtownfreerider's Avatar
    you can also use windex, but go with lock on's
    PUNK FOR LIFE
    freeride & Down hill for life
    Companies I support
    E-13
    Shimano
    Maxxis
    EBC
    Marzocchi
    SIXSIXONE
    Specialized
    Arrow Racing
    Truvativ
    W.O.R.B.A. supporter
    I.M.B.A. supporter
    Reputation: standard235's Avatar
    Air is the best. Next is lockons. If you have O/S bars, barends have to be forced in but still work. I ditched my Raceface Lockons for a pair of ODI Ruffians. Much better feel IMO.
    I just stick them in some boiled water for about 30 seconds, they slide on with ease .
    I used the hairspray and It worked like a charm. Only complaint is that it smells like sh!t for a long time, and is a real pain to get off the exterior of the grips if it happens to float onto them. Worked great though, thanks for the input.
    Erik
    nothing wrong with your bike selling like a french whore.
