quick kona coiler question- Mtbr.com
Results 1 to 10 of 10
    Just a quick question about the 2005 coiler. Whats the tire clearance? Can i run 2.5's?
    Deadhead
    2.5s will fit with room to spare. I ride an '04 Deelux and the rear end is the same on the '05s. I'm currently running Kenda Blue Groove 2.5 with enough room to go up to the 2.7 if I wanted.
    Unshaven Yak
    Reputation: Stinky Wiz's Avatar
    I'm running 2.5 Timberwolves on my 04 model with PLENTY of room to spare, looks like the rear has room for a 3.0. The front is a tad tight though with my 04 Z1FR (slight signs of rubbing on inside of arch on opposite side from the disc). The new Zokes look like they might have a bit more clearance though.
    I've also run 2.5 Michelin DH comp with lots of room & a 2.5 Trailbear with equal success.
    Are coilers good for north shor stuff?
    Quote Originally Posted by MaTT_133
    Coilers are basically just Stinkys, with a slightly less burly frame, lighter, and easier to pedal. Im sure it could take alot of north shore stuff if you upgrade the fork.
    Don't skid
    Reputation: KONA_in_SB's Avatar
    I disagree about tire clearance. I am running a 2.5 Timberwolf in the rear and although the frame has plenty of room my chain rubs on the tire when i'm in the small chain ring. It gets very annoying.
    Deadhead
    Quote Originally Posted by KONA_in_SB
    That's more a factor of BB spindle length than tire clearance in the frame. If you have a narrow BB, say 113 or smaller, you could have potential problems. Anything wider and there should be no issues.
    im not switching out the bottom bracket from stock, but i wanted to know if i could run 2.5 in back and 2.6 in front. I guess that means whats the max that the Zokie Drop off comp can take? Looks pretty wide to me
    Deadhead
    You should be OK with the 2.6 in front. You might see a little rubbing on the inside of the fork arch like Stinky Wiz posted above. I run a 2.5 on an '03 Z1 which has less clearance than the newer models.
    Don't skid
    Quote Originally Posted by gratefulbiker
    Cool, I didn't know that.
  1. quick headset question (need help)
    By smoofers in forum General Discussion
    Last Post: 09-09-2004, 07:32 PM
  2. Giant VT or Kona Coiler?
    By fanfare in forum Giant
    Last Post: 09-08-2004, 01:46 AM
  3. Kona Caldera question
    By JudyR in forum Bike and Frame discussion
    Last Post: 07-28-2004, 09:14 AM
  4. Replies: 8
    Last Post: 07-01-2004, 07:07 PM
  5. Kona Coiler
    By Jeepstarr in forum Bike and Frame discussion
    Last Post: 06-26-2004, 12:19 AM
