quick, help me find a cheap BB for my build- Mtbr.com
Results 1 to 11 of 11
    _
    Reputation: slothoncanvas's Avatar
    Hey. I have these cranks that I got a while ago and i finally got a frame to start building up...
    ...Mountain Cycle Rumble, it's sick. I'll post a pic and thread when I get it all built.
    Anyway, here are the pics.
    And in the Manual for the Rumble, it says the BB 73mm shell.
    So, I dunno. If you know of any on sale, let me know.
    ...Otherwise just let me know the size and BB type i'm lookin for if you can.
    Thanks a lot.
    Here are the pics.
    Meh.
    Reputation: XSL_WiLL's Avatar
    That's a Howitzer interface. Only Truvativ makes it.
    _
    ...ok? so is that the only type Truvativ makes?
    And can they be found under or around 30.00?
    And when i'm looking at sizing, does it have to say 73mm or is there any other sizes i can use. Oh also i'm going to run a bb mount chainguide, so. if that makes a difference.
    _
    oh yeah and what's a Chainline?
    ...sorry i know like absolutely nothing about bb sizing. and i don't want to buy the wrong size and be out money.
    Meh.
    Truvativ also makes GXP (won't fit) and ISIS (won't fit) and PowerSpline (won't fit).
    The chain line is the center line between the center line of the frame and the center line of the crankset. Basically, it's going to be how far out the cranks sit. The middle of the cassette should line up with the middle chainring position.
    You probably need the narrower chainline.
    _
    Quote Originally Posted by CanadianPreston
    Ok cool thanks guys.
    Is that def what I need cuz I'll buy that right now?
    Oh yeah and I have a traditional BB tool but don't you need a special tool for the Truvativ or something?
    _
    http://pricepoint.com/detail/15560-030_TRUHX6-3-Parts-48-Bottom-Brackets/Truvativ-Howitzer-XR-Bottom-Bracket-'07.htm
    that's the same one yeah?
    And should i just get that in the 68/73 x 50mm?
    oh yeah and then I'm getting the Sette Hallowtech BB tool.
    Spend ten more dollars and get the Team BB. The Sette tool will work, yes.
    _
    ok but will the one I have a link to there on Price Point fit?
    Yes it will fit, any of the Howitzer BB's will. I just recommended the Team version because it is known to last longer and perform better than the XR version.
