Q for Hayes brakes users- Mtbr.com
Results 1 to 10 of 10
    Rollin' a fatty Moderator
    Reputation: DiRt DeViL's Avatar
    While riding our (me and son) lever reach adjustment changes to the farthest adjustment. We re-adjust and it changes again, this is a recurrent problem and it's starting to really annoy me.
    Seems that the vibration moves the adjusting bolt, have heard about locktiting the bolt to prevent this but causes the stripping of the bolt later.
    Do your levers reach changes while riding?
    If so what do you do to avoid the change in reach?
    Reputation: wyrm's Avatar
    Try the Straitline barrels... They work good if properly installed. Get the right size... size by 4mm or 4.5mm.... never by H-9 or Mag. Some Mags have 4mm like mine.
    http://www.straitlinecomponents.com/...arrel_nuts.php
    Bikeless Rider
    jhn
    jhn is offline
    Every Hayes have same problem. Just put Locktight in the bolt.
    Call Hayes they will send you a set of new barrel adjusters that have a nylon thread insert to correct your problem
    squish is good
    Reputation: Clutchman83's Avatar
    Nylon tape or blue locktite will fix you up. Just use the locktite sparingly and reapply when necessary. DO NOT use the red stuff.
    Bike good, work bad.
    Gaa-zee-raaaa!
    Reputation: Godzilla's Avatar
    Mar 2005
    Be careful, get the smallest bit of loctite between the barrel and the lever itself and your brake levers will not return once you've released them - it's not a big deal to fix, just a needless hassle, especially if you discover the issue on the trail.
    Now with more vitriol!
    Glad to Be Alive
    Quote Originally Posted by jhn
    yep and I never had one strip
    BrassBalled DropbarNinja
    Reputation: mrpercussive's Avatar
    i had one which stripped... called hayes up and they sent me a new one in no time... Hayes CS is awesome!!!
    hmmmm
    Reputation: Dalis12's Avatar
    never had a problem with my Mags. friend has had to use loctite with his nines
    Reputation: rustyskills's Avatar
    blue loc tite and be very care to only get a little bit on the threads
