Project that Gwillywish and I are working on...- Mtbr.com
Results 1 to 14 of 14
    We got bored so we decided to paint his Steelhead something other than black....
    He's n00b so he wanted naked steel (With clear enamel) so we are.
    I just finished wet sanding with 2k grit. Need to clean it up some more and then prep before painting.
    Will update with pics tomorrow if we finish.
    howd you strip the frame? ive got an old bmx frame i wanna do..
    I went to the doctor and told him "hey doc, it hurts when I go like this" and the doc said "Does the rear feel too soft?"
    Apr 2005
    that is going to be very ugly. you two are way upsets with painting frames ugly a$$ colors. you really should have rode with me today, the trails were perfect. the DH, DJ's, and MTX will need a little bit of grooming but were great to ride.
    We just used this stuff called Paint Stripper. Spray on, let bubble up paint, wipe off. You should prolly just spray it on and pressure wash it off.
    We got through 2000 grit on it, needs to be gone over again though.
    EDIT: Just laid down a coat of Panther Pink. Hehe. Looks sick.
    @wishEMT
    Reputation: gwillywish's Avatar
    pretty sick man: not quite done yet, but sick, custom mixed can
    Apr 2005
    meh! ugly, but hey there is my sh!ty Free Agent Eluder
    Meh.
    Reputation: XSL_WiLL's Avatar
    I see understray, overspray, and runs. Reminds me of your p.bike.
    Should've atleast taped the threads. Did you lay down a few coats of primer with a wet sand between each?
    For what it's worth, use aircraft stripper and a scotch brite pad.
    You do realize that you have nothing positive to say about anything I do right?
    My P. Bike is **** compared to this. No, I did wet sanded with 2k, surface prep, then 2 coats of pink. Wet sanded, 2 more coats, wet sanded, 2 coats of clear. I will be doing 2-3 more coats tomorrow.
    Meh.
    I firmly believe in taking the time to do things right. Critical surfaces and threads should have been taped off. At this point, it doesn't matter, I would just take it to a shop and have the frame prepped. Threads chased, surfaces faced, honing, reaming, etc.
    Underspray is not a big deal, you are usually able to see through the first coat. It is right to lay down many many thin coats. But if that's after 4 coats of color already... you may need to rethink how you're approaching it.
    The P.bike wasn't terrible, just a few runs.
    Curing it usually makes it more durable if you have something big enough.
    I'm not a big fan of aerosol, but if it's what you got, use it.
    Why already clear if you plan to put on more color?
    moaaar shimz
    Reputation: tacubaya's Avatar
    Wheres a pic of that P you guys keep talking about?
    I have one. I'll put it up in a minute.
    No, I didn't do any more color. Just clear today. There's 2 miniscule spots that are slightly faint, but oh well.
    DWF
    DWF is offline
    Non Dual Bliss
    Reputation: DWF's Avatar
    Stick with that. It's becoming a rare commodity.
    A man must have enemies and places he is not welcome. In the end we are not only defined by our friends but those against us.
    Finished product. Just need to get a new cable, cut the housing and put a housing end on it.
  1. am1 eta not working
    By chenpj in forum Shocks and Suspension
    Last Post: 07-20-2005, 12:57 PM
  2. Newbie working on project
    By bike_bob in forum Singlespeed
    Last Post: 07-30-2004, 08:13 PM
  3. Working On It Still!!!
    By crazbiker4 in forum Downhill - Freeride
    Last Post: 04-14-2004, 07:07 AM
  4. Help: ECC not working in my z1 sl
    By Louis in forum Shocks and Suspension
    Last Post: 03-14-2004, 01:36 PM
