Pike click- Mtbr.com
Results 1 to 3 of 3
Thread: Pike click
    crumb
    Reputation: saviorself's Avatar
    Dec 2004
    Pike click
    Hey, I got a Pike team with poploc and when I compress it when its at full travel it clicks about 40mm through the travel with no compression adjust or anything When I wind down the travel to about 120mm it doesnt have the click any more. Anybody have this problem or a solution?
    Thanks alot
    Jim
    crumb
    Dec 2004
    Solution: If you extend the travel too much and it clicks when its compressed cycle the uturn all the way to the bottom and back out making sure not to extend it too far (just untill you see the marker) and the click is gone. It took me 20min to figure that out
    Meh.
    Reputation: XSL_WiLL's Avatar
    Quote Originally Posted by saviorself
    Thanks alot
    Jim
    It's the spring knocking around the inside of the stanchion. Wrap some saran wrap or a old tube around the spring.
